Just curious if anyone knew of some cases that open on the RIGHT side instead of the standard left (if you are looking at it from the front). Right now I have my build inside an old HP case which opens on the right and its the only way it will work with my desk setup.
If it were to open on the left as well as the ventilation, it would vent directly into a wall and cause me heat issues and I don't want that. I don't have any other way to set up to allow me to use a left side case so please don't suggest that.
Also budget isn't too high... I've been sitting here going through Newegg and everything seems to open on the left. Also Google searching isn't getting me anywhere. This is so frustrating.
