UPDATE: Got new same model HP motherboard, encountering new issue detailed in another post below
Hey guys,
I had a HP desktop which I changed the Processor, graphics card and Power Supply on. Lasted me about a year and a half....but now the motherboard as gone out on me. I don't want to build a completely new system at the time, I'm just going to order a new motherboard and get the PC I had back up and working. I don't really know too much about the hardware side of computers though and this forum has been great help in the past. Basically I'm looking to spend around $60ish for a new motherboard if possible that will work with the following:
-AMD Athlon II X4 640 Propus 3.0GHz Socket AM3 95W Quad-Core Desktop Processor
-Radeon HD 6770 1GB 128-bit DDR3 PCI Express 2.1 x16 CrossFireX Support Video Card
-CORSAIR Builder Series CX430 430W Power Supply
-4GB System Memory
-500GB Harddrive
Could any one point me in the right direction on what kind of motherboard I would need for this and if possible to get one in the price range I'm looking for?
While I'm at it, I wouldn't mind replacing the RAM in this PC either, as games do take quite some time to load...but once loaded they run completely fine on decent settings. So depending on the new motherboard, some new RAM that will work with the new one would be a nice upgrade as well, if it isn't too expensive. Not sure what kind of RAM would be the best bet to get here either.
Thanks a ton in advance guys!
Hey guys,
-4GB System Memory
-500GB Harddrive
