Will this build work?
Last response: in Systems
January 10, 2012 7:52:10 PM
Hello All im building a new computer and i want to make sure everything is compatible with each parts, im pretty sure it all is but im just making sure. thanks
XCLIO Windtunnel Fully Black Finish 1.0 mm SECC Chassis ATX Full Tower Computer Case
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
EDIMAX EW-7128Gn PCI Wireless Adapter
EVGA SuperClocked 012-P3-1573-KR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP
Antec High Current Gamer Series HCG-750 750W ATX12V v2.3 / EPS12V v2.91 SLI Certified CrossFire Certified 80 PLUS BRONZE
Team Xtreem LV Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2000 (PC3 16000) Desktop Memory Model TXD38192M2000HC9KDC-L
AMD FX-8150 Zambezi 3.6GHz Socket AM3+ 125W Eight-Core Desktop Processor FD8150FRGUBOX
COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible
OCZ Onyx Series OCZSSD2-1ONX32G 2.5" 32GB SATA II MLC Internal Solid State Drive (SSD)
More about : build work
January 10, 2012 8:21:53 PM
The only thing not listed is what mainboard you are using for your FX CPU other than that all looks good.
m
l
a c 83 B Homebuilt system
January 10, 2012 8:29:36 PM
Motherboard? Budget?
Personally not a big fan of that case. I have read that it is a big dust magnet and the fans fail at a pretty high rate.
Any reason you are getting the 8150 and not a 2500K?
Where are you buying from?
I would go with GSkill or Corsair RAM personally. I have never heard of Team Xtreem.
A 32Gb SSD is pretty small....too small for anything but Windows and a few programs. I have a 120GB SSD and still have to be careful how many games I have installed. Some games can be 15GB all by themselves. If you were getting a Z68 system then you could use that small an SSD for caching.
m
l
January 10, 2012 8:58:11 PM
my budget is about 1500 dollars, and i personally am i a fan of amd cpus, and my SSD just for my OS and i have a bigger hdd at my house. im buying it all from newegg, and i was ify on the case so thank you. and my motherboard is
GIGABYTE GA-990FXA-UD3 AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard
m
l
January 10, 2012 9:03:55 PM
Newegg has the Antec 300 Illusion on great sale right now. I have used them in quite a few builds. Great case for the money.
I would still get GSkill or Corsair RAM.
That SSD is going to leave you disappointed. It's up to you of course but in my opinion that is just too small for a system drive. Once you use an SSD you are going to want all your programs on it.
m
l
January 10, 2012 9:20:35 PM
ok thanks of all the help
m
l
