It is a LCD viewsonic 19' inch, I think it is a bit old because it is 5:4 with max res of 1280x1024.
My monitor is all gray when I switched it on, normally it is all black. I tried turning it on and off, removing the connection between the monitor and the video card but it still doesn't work.
I tried opening the OSD menu but nothing shows up on the screen. I can see a very washed out image of my desktop after turning it on but it will slowly disappear.
At first I was nervous that it was my video card which is a 5870 that is broken, but I borrowed another monitor and it worked.
Do you think it is already broken?
I do not mind replacing it because I have been thinking of replacing it with a 23' or 24' inch for some time now.
