3 motherboards- 2 have same problem and 1 is working.
  • Motherboards
  • CPUs
March 5, 2013 4:06:53 AM
Asus p5kpl am/ps - 3 motherboards
Intel core2duo cpu E7500 for testing.
450W working PSU for testing.
One motherboard is working. So I can check the voltage and compare it with the faulty one.
Symptoms on both faulty motherboard is no display and no beep.
Can you guide how to solve this problem?
I am using same CPU and PSU for 3 motherboards.
Additional
I have even changed the BIOS IC's from good motherboard to faulty motherboard but still same problem and the faulty motherboard BIOS chip's are also working on good motherboard.
More about : motherboards problem working
a c 1173 V Motherboard
a c 909 à CPUs
March 5, 2013 10:04:34 AM
Most likely a faulty chipset on the broken boards but look for blown or bulging capacitors on the broken boards before you write them off.
m
l
March 5, 2013 8:32:58 PM
I had checked it before for and uneven shape on them. Nothing wrong with the caps. And how to check the chipset IC's?
m
l
a c 909 à CPUs
March 5, 2013 8:34:59 PM
Cant basically not worth repairing.
m
l
March 5, 2013 9:03:42 PM
No Problem :)
m
l
