First build (Parts compatible?)
Hello everyone,
I am building my first computer and was just wondering if all the parts were compatible. Since this is my first computer I am keeping the cost low just in case I screw anything up. That being said I plan on using this thing for 2-2 1/2 years as I save to build my second and way better computer. So will this thing be able to handle games such as dcuo and star wars: TOR?
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813138293
http://www.newegg.ca/Product/Product.aspx?Item=N82E16817339001
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231274
http://www.newegg.ca/Product/Product.aspx?Item=N82E16819103995
Gpu will be a Gigabyte Radeon HD 5770 or something similar.
This is a extreme budget build I know, but other priorities force me to build this and wait a little longer to save 1-2k for my main rig.
3 answers Last reply
More about first build parts compatible
  1. Hello Betlosedrink;
    Your parts are compatible. But if your graphics card is going to be in the HD 5770 class you might as well save some money with a CPU/MB combo like this:
    Athlon II X3 450 Rana 3.2GHz & BIOSTAR N68S3+ AM3 - $108.98
    http://www.newegg.ca/Product/ComboDealDetails.aspx?ItemList=Combo.797783
    If you can - spend that savings on a better graphics card.
  2. Your parts are good.
  3. WR2 said:
    Hello Betlosedrink;
    The gpu is only a temp card. I plan on upgrading it asap. It will probably last me a month or so then I will upgrade it. The card is just one I'm getting from a friend. With that said, should I stick with the currents parts I have?
Build Computer Compatibility Systems
