Hi,
Not sure if this is the right forum -- but I'll give this ago.
I want to try to set up a GPU based computing platform try tinker with OpenCL -- a programming system that allows you to send computationally intensive tasks to a GPU.
I have an HP Proliant DL 585 g2 machine ... sadly as I found out it does not have any Molex or other power connections available -- it was designed for cable less operation. And, I was stupid enough not to do enough research and know that GPUs require additional power as they are very power hungry.
I next tried to feed the GPUs using an external PSU hotwired to turn turn on ... I couldn't get it to work though I didn't get the error from GPUs that the power is unhooked.
I didn't ground the power supply to the Proliant -- I figured since they share the same AC power source they're probably grounded.
Any advise?
Thanks.
Any advise?
Thanks.
