Sign-in / Sign-up
Centrino intell pro wireless lan 2100 3a wont connect to netgear
  • Connection
  • Netgear
  • Wireless Lan
  • Wireless Networking
Last response: in Wireless Networking
April 28, 2011 2:43:37 PM
Dell 8600 centrino intel pro wireless lan 2100 won't connect to netgear n150 wnr1000. Running 802.11b band it sees wireless network but won't connect. I have 2 other computers connected to network so it works.... I don't know if Netgear n150 is compatible with 802.11b band...
More about : centrino intell pro wireless lan 2100 wont connect netgear
April 28, 2011 4:08:20 PM
It's probably the wireless card can't work with the security standard you have set for the router. As a test, don't use any wireless security and see if you can connect. That LAN chip has issues connecting to some networks, I think it's one used in the IBM T40 and T41 models (maybe 2200 and not 2100), and I have seen issues with them. Get an external wireless card, should work then, they are pretty cheap.
m
l
