USB wireless v internal wireless
I assume that internal ones are better? If so which are the best internal cards?
3 answers Last reply
More about wireless internal wireless
  1. Anyone?
  2. In my personal experience, they performed absolutely the same. I couldn't tell you the difference between them for playing shooters and other fast-paced games.
    However, when I was using the USB WiFi adapter it would occasionally drop the connection to my router and I would have to unplug it and plug it back in to reconnect. So if you have the option try to get a PCI WiFi adapter.
    I used: Lynksys AE1000
    I now use: Rosewill RNX N300X
  3. Thanks
Wireless Internal Wireless USB Components
