Looking for some input on this new system. I plan to run four monitors for business applications and some photoshop. What do you guys think ? Will this be sufficient. I will not be gaming .
Any increase in RAM ? Vid cards alright ? Mobo alright ? 750W enough power?
Also - this is my first computer I will be putting together - are all the necessary cables included with each of these parts ?
Thank you
Sony Optiarc CD/DVD Burner Black SATA Model AD-7261S-0B LightScribe Support - http://www.newegg.com/Product/Product.aspx?Item=N82E16827118040
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
Dual SAPPHIRE Vapor-X 100327VXL Radeon HD 6750 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card - http://www.newegg.com/Product/Product.aspx?Item=N82E16814102943
CORSAIR Enthusiast Series TX750M 750W ATX12V v2.31 / EPS12V v2.92 80 PLUS BRONZE Certified Modular High Performance Power Supply - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139030
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBXL - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231428
MSI P67A-GD65 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E16813130574
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD) - http://www.newegg.com/Product/Product.aspx?Item=N82E16820148441
Subtotal: $986.91
Thank you
Subtotal: $986.91
