Hey,
I apologize in advance if this topic is in the wrong location. I just built my first machine (below) and it won't power up. I'm almost positive I have everything hooked up correctly, but nothing happens when I hit the power button.
The case I'm using is a Define R4, and there were a few cables coming from the Front Side that I didn't know what to do with. I correctly identified the smaller cables for the Start Button, Reset Button, and Power Light. However, there was one power cable (a thicker 4 pin cable) that I assume is for the Fan controller and three with only two pins, not sure what those are for. Are those needed to start the computer?
If that's not the issue, would it be the Power Supply? Is there a way to test the Power Supply without the motherboard/case?
I'm not sure what type of advice you guys could give, but anything would be helpful. I'm sorry if this post is all over the place, but I'm not sure how to attack this.
gigabyte ga-Z77X-UD3H
intel i5-3570k
Corsair Vengeance 16GB DDR3-1600
GeForce GTX 670
Corsair 600W ATX12V
Thanks in advance!
Matt
intel i5-3570k
GeForce GTX 670
Corsair 600W ATX12V
Thanks in advance!
Matt
