Closed
Five 550 And 600 W 80 PLUS Platinum Power Supplies, Tested
  • Platinum
  • Power Supplies
  • Product
Last response: in Reviews comments
Anonymous
a b ) Power supply
February 6, 2013 3:00:04 AM
A good power supply doesn't just provide you with ample output. Increasingly, vendors have put a bigger emphasis on delivering power more efficiently, too. We're testing five 80 PLUS Platinum-rated power supplies in the 550- to 600-watt range.
Five 550 And 600 W 80 PLUS Platinum Power Supplies, Tested : Read more
More about : 550 600 platinum power supplies tested
February 6, 2013 4:19:48 AM
Either the Rosewill FORTRESS was defective or your calibration was off for the last test. Your o-scope shots do not match those of other highly credible reviewers. Also, I'm curious of your testing methodology, but it was not listed.
Score
6
Anonymous
a b ) Power supply
February 6, 2013 4:50:22 AM
what? no overload it until it blows test?
and i was making popcorn.
Score
12
February 6, 2013 5:06:25 AM
Is that a typo in the first chart for Kingwin's Lazer? It claims that it fails 80 Plus's 50% load spec (82% of 92%); I assume that was meant to say 92% (since that's what the chart below it shows).
Pleasant read, though, I like PSU reviews.
Score
February 6, 2013 5:24:31 AM
What happen to Seasonic? They have the 520W fanless SS-520FL Platinum version. No PSU test is complete without a seasonic to compare to, in my own opinion.
Score
13
a b ) Power supply
February 6, 2013 5:38:37 AM
jupiter optimus maximusWhat happen to Seasonic? They have the 520W fanless SS-520FL Platinum version. No PSU test is complete without a seasonic to compare to, in my own opinion.
they asked for vendors for the PSUs. Theres the offshoot chance that seasonic declined the offer. On other sites, the 520w fanless seasonic unit was compared to Rosewill's 500w silent night unit. The seasonic unit I believe in that review barely edged out a victory.
Score
6
February 6, 2013 5:39:24 AM
iknowhowtofixitEither the Rosewill FORTRESS was defective or your calibration was off for the last test. Your o-scope shots do not match those of other highly credible reviewers. Also, I'm curious of your testing methodology, but it was not listed.
I believe this is still applicable to all of the power supply testing our German team does: http://www.tomshardware.com/reviews/psu-test-equipment,.... I'm waiting for confirmation that I'm right.
Edit: Yup, that's the correct testing equipment/procedure!
Score
5
Anonymous
a b ) Power supply
February 6, 2013 5:47:03 AM
Dun dun dun..................... no acoustic performance measured, the only reason some people buy high end PSU's.
Score
February 6, 2013 9:44:17 AM
WOW! Thanks a bunch for including the 25watt "Low-Power PC" efficiency test! All other reviewers stop @ 20% load witch is not "idle" or "low load" at all. :-)
Score
5
February 6, 2013 9:44:38 AM
Power supply unit is where a system builder cannot use a word "BUDGET"
Score
February 6, 2013 10:08:03 AM
I don't understand
Why is the 80 plus spec officially test by having more load on the 3.3v and 5v rails?
Clearly loading the 12v rail would give us a better overall image
Score
a b ) Power supply
February 6, 2013 10:08:51 AM
no internal build break down? i don't think jonny guru and hardwaresecrets have anything to worry about in competition.
Score
5
a b ) Power supply
February 6, 2013 10:59:45 AM
Interesting, IMHO the most important aspect is 'Ripple Voltage' @ Rated Load. The only mention I see is a vague reference in your conclusion page.
Never mind I see the ripple data buried in the individual tests. It would have been better in the summary side-by-side tests.
Nice article.
Score
February 6, 2013 11:52:13 AM
cangeliniI believe this is still applicable to all of the power supply testing our German team does: http://www.tomshardware.com/review [...] 2657.html. I'm waiting for confirmation that I'm right.Edit: Yup, that's the correct testing equipment/procedure!
Sorry!
The page you requested couldn't be found
Score
Anonymous
a b ) Power supply
February 6, 2013 12:01:48 PM
sanilmahambre said:
Power supply unit is where a system builder cannot use a word "BUDGET" "CHEAP"
fix'd that for ya :)
Score
7
February 6, 2013 2:18:16 PM
Sometimes in reviews like these there've been products that produce disappointing results compared to well known manufacturers. So why do they send their stuff in the first place knowing that their product is of lower quality than the competition. Do they gain something from these reviews? Just curious.
Score
February 6, 2013 2:53:37 PM
By reading this article, i just thought of a great idea and help for us users, a Best PSU for your money guide, i think that would be incredibly helpful since PSUs are hard to buy and to know wich ones are really good, of course i know that is a lot of work, but it could be like once or twice a year and not monthly like Video Cards and CPUs, what do you think about it?
Score
a b ) Power supply
February 6, 2013 3:39:35 PM
I guess these psu's are only for bragging rights. For 120, you can get good 700-800w psu
Score
-1
February 6, 2013 3:40:37 PM
iknowhowtofixitSorry!The page you requested couldn't be found
Sorry, take the period out of the end of the URL.
Score
-1
February 6, 2013 4:29:54 PM
Quote:
But two of these products stand out from the crowd: Cooler Master's Silent Pro Platinum gives us unprecedented power efficiency, followed by the value-packed Rosewill Fortress 550.
Quote:
Most of the samples we reviewed exhibited minor flaws. For example, Rosewill's Fortress 550 exceeds the maximum allowable ripple voltage on the 12 V rail, which is an indication of cutting corners in circuit design or component quality.
Your priorities are obviously backwards. Rosewill's entry, by your testing, failed to meet ATX spec by producing an unacceptable amplitude of ripple on the 12V rail. By definition, this is a fail. This isn't a minor flaw, this is violating spec. A failure can not stand out from the crowd (at least in a positive sense). Now, there are other posters here that dispute your results, but you don't have that luxury. Both your results and summary comments indicate that this unit is a failure no matter how good the efficiency, price, or other metrics look.
You can argue the importance of efficiency versus DC output quality all you want when the unit meets spec, but all of the components in your system rely on PSUs to actually meeting spec in order to function properly. Without meeting spec, there is no way to guarantee components will work properly. In fact, failing to meet spec pretty much guarantees that some component somewhere will not work properly. I've seen enough devices (granted poorly designed) fail to work properly with PSUs that had ugly DC quality, but were technically within spec to recommend one that is out of spec.
Score
7
a b ) Power supply
February 6, 2013 4:59:24 PM
I would like to see a fully modular PSU review.
Also, the difference in cost between the Gold and Platinum rated models seems to negate the power savings one would realize by going with a Platinum model. Since I do run a few of my machines 24/7, I am curious to see where the efficiency lies for low power consumption for a variety of 80+ certified models as this level of power consumption occupies a large majority of the up-time (70+%).
Score
February 6, 2013 5:10:49 PM
Azn CrackerI guess these psu's are only for bragging rights. For 120, you can get good 700-800w psu
Or, you know, power savings, coupled with not needing 700-800 watts.
Score
February 6, 2013 5:23:05 PM
I think the PSU is the most important component on the machine. If it fails or over-volts a rail it will kill components. So I usually get the highest effeciency PSUs because I can be sure they would need good build quality in order to get that rating. Last one I did, I stuck an Antec Earthwatts 550w platinum in a machine. I liked how it was not that expensive for a platinum psu, I can live with 1% lower effeciency.
Score
a b ) Power supply
February 6, 2013 7:10:49 PM
Zagen30Or, you know, power savings, coupled with not needing 700-800 watts.
The power savings over a proper Gold or even Silver are often too small to matter with low wattage systems. If you don't needs 700-800 watt PSUs, then getting a cheaper lower wattage model that's still high-quality means more for the money and more money that can go somewhere more important.
Score
February 6, 2013 7:56:40 PM
Rosewill = newegg = major sponsor of tech review site = biased useless information
Score
4
a b ) Power supply
February 6, 2013 8:15:55 PM
Andy ChowRosewill = newegg = major sponsor of tech review site = biased useless information
Are you accusing Tom's of not being objective in this review? If so, then you'll have to do better. Rosewil, although they sell many products on Newegg, is not a part of Newegg. Furthermore, according to reviews of that Rosewill PSU from other sites, it would seem that Tom's simply had a defective unit.
Score
a b ) Power supply
February 6, 2013 8:34:33 PM
Precisely. A quality 700W PSU is enough to Crossfire/SLI even the highest end cards. The ~500W range is more than adequate for any single-card configuration + OCing. Typically a high quality 500W will run the same as a a lesser 750W, so why wouldn't I want the more efficient model?
Score
February 6, 2013 10:07:27 PM
RedJaronPrecisely. A quality 700W PSU is enough to Crossfire/SLI even the highest end cards. The ~500W range is more than adequate for any single-card configuration + OCing. Typically a high quality 500W will run the same as a a lesser 750W, so why wouldn't I want the more efficient model?
They may have different management structures internally. But, rest assured, Newegg and Rosewill are owned by the same people...
Score
February 6, 2013 11:22:45 PM
blazorthonAre you accusing Tom's of not being objective in this review? If so, then you'll have to do better. Rosewil, although they sell many products on Newegg, is not a part of Newegg. Furthermore, according to reviews of that Rosewill PSU from other sites, it would seem that Tom's simply had a defective unit.
I'm accusing both Tom's and the commenter. The Rosewill PSU does not meet ATX specs. It does not qualify as a platinum PSU, It even seems like a very bad PSU, from all the ripples etc. Then Tom's recommends it?
Tom'sBut two of these products stand out from the crowd: [...] Cooler Master's Silent Pro Platinum gives us unprecedented power efficiency, followed by the value-packed Rosewill Fortress 550.
I don't believe the commenter claiming a defective unit was impartial either. Probably the same dude who sent in the unit. Claiming Tom's does not have an interest in maintaining a healthy relationship with Newegg ... is ... laughable.
Score
a b ) Power supply
February 7, 2013 12:13:37 AM
Andy ChowI'm accusing both Tom's and the commenter. The Rosewill PSU does not meet ATX specs. It does not qualify as a platinum PSU, It even seems like a very bad PSU, from all the ripples etc. Then Tom's recommends it?I don't believe the commenter claiming a defective unit was impartial either. Probably the same dude who sent in the unit. Claiming Tom's does not have an interest in maintaining a healthy relationship with Newegg ... is ... laughable.
in the review it says
Quote:
At the end of the day, Cooler Master, Enermax, and Kingwin share a first-place finish in today's round-up, and prospective customers should make their decision between those three power supplies based on your own criteria (price, the number of 12 V rails, connector counts, and so on).
so where does it explicitly say that its the recommended unit of the 5 again?
Score
February 7, 2013 1:07:48 AM
this is the psu i would get personally if i need another for my current pc.
its unlikely that i would ever need it, but thought i would post it here.
nice, cheap, and high efficiency not to mention VERY solid build and parts inside that allow for FAR more wattage than this thing can handle.
Score
-1
February 7, 2013 2:02:22 AM
Did you happen to read the only review on the product (customer said the unit arrived defective). He still gave it 4 eggs, though. Funny.
Score
February 7, 2013 2:55:19 AM
dirtyferretno internal build break down? i don't think jonny guru and hardwaresecrets have anything to worry about in competition.
jonnyGURU is a place I go to for hardware tests as well, but I wouldn't put them above Tomshardware by any means. Frankly I think he showed a bit of leniency and bias in this article:
http://www.jonnyguru.com/modules.php?name=NDReviews&op=...
The article points out build flaws that I would have flat failed the unit for, stamping it with a big "DO NOT BUY" in red letters. Instead, he says it was a good unit that just didn't compete with the better products.
I can easily see someone buying a Zeus because it's on for a sale price - "johnnyGURU said it was good enough, why not save some money?" Why not is because 3 years later those little ugly solder joints are going to come around to bite you in the behind. Mine took out my mainboard and CPU with it (after the 3-year warranty expired of course). Thanks, Silverstone.
I didn't read reviews on the Zeus until after the fact because I trusted Silverstone. It was a bad move, and Silverstone is the reason I now tell people "Don't by just by brand, buy a PSU that you've read good reviews of." But if a site isn't very clear about the problems of a product, a potential user isn't going to be forewarned, and jonnyGURU is being a part of the problem here instead of the solution.
Tomshardware was one of the first sites that starter testing computer PSUs - and telling us how bad they were. This site is in no small part responsible for the increase in quality we have seen in the last decade. Now, I do think Toms has changed a bit, not all for the better, and they are just as capable of being a bit biased or sloppy as anyone else, but jonnyGURU is NOT someone to hold up as a standard for PSU reviews. Yes, the site does a good job, but it doesn't do a great job.
I'm not intentionally picking on jonnyGURU more than Hardwaresecrets or anyone else, it's just that the particular review of the Zeus stuck in my mind so I use that as an example. These are all good sites (If I had to talk "best quality" today I would say Anandtech.com; of course they aren't infallible either), but just like the PSUs themselves, you have to read them with a clear head and open eyes and pay attention to the details. So, like, I know that if jonnyGURU gives a "7.5" for build quality, that means a "don't freakin buy if it's the last PSU on earth" in my book.
Score
a c 154 ) Power supply
February 7, 2013 11:29:25 AM
What's with the fixation on efficiency ? To me, voltage stability and ripple are the most significant properties of a PSU. This article provides 50% of that information making it useless to me. The ATX spec allows 5% voltage fluctuation whereby the minimum I consider a requirement for great overclocking potential is 1%. When voltage is flopping around all over the place under highly variable loads, it makes it difficult to maintain stable OC's.
How important is efficiency ? Let's assume 4 hours per day on weekdays and 8 hours per day on weekends ...... or 36 hours a week. Let's use 92% and 90% as the range of efficiency in this article.
36 hours x 4.3 weeks per month x (550 watts/1000 watts per kw) x (92% - 90%) x $0.10 per kwhr = $0.17
How many peps just went "Holy crap, I'm glad I read this article....now I can save 17 cents per month on my electric bill" ?
Score
February 7, 2013 12:22:30 PM
If ya concerned about objectivity, ya might ask why the dollar categories for the Best GFX Cards each month change, shifting the boundaries up or down from month to month ? Ya might ask why the HD charts show speed rankings and yet the top units don't make it into their "Build for $xxxx" articles even though they the same price as the selected units. Is the selection influenced by the other News article that said "XXVendorXX" just sent us 10 Model ....." and they just happened to have 9 more on hand after doing the HD article ?
Is this online payola, is it author bias, is it a Fox News kinda version of "fair and balanced" approach, is it an accuracy issue ? Is it simply a difference of opinion ? Who knows ? It' just makes one stop and ask "For what reason would they keep changing the dollar categories all the time ..... and when ya look, it usually falls out that when the $180-$210 category topped out at $220 last month, there's a $215 "winner" that got squeezed out of the category and is now competing with cards in the $210 - $250 range. Is there an attempt to favor one brand over another ? Or is the opposite true....is there an attempt to keep all players happy ?
The worst instance of this I have ever seen is a PC magazine article from back in the mid 1990's. It probbaly didn't get a lot of attention from the gaming community as it as a database article. In the 12 categories, Microsoft Access garnered 7 excellent ratings and 5 good.....Lotus Approach garnered 11 excellent and 1 good. They TIED for Editor's Choice. I immediately imagined a Newspaper Headline ..... First Superbowl Tie Ever .... "New York Yahoos 33, Washingtom Wackos 15" !
Yes, I still come here and do find the articles useful but I don't believe all of the articles are without "market" or "marketing" influences. For product selection, I'm not going to use a site that compared 5 PSU's or 5 GFX cards for a purchasing decision under one set of criteria and try and compare that with another article 3 months later with another 5. I'll rely on a site that provides a historical database of hardware tested that goes well into the double digits of units so I can make a valid comparison.
Not picking on Toms .... not saying they are better or worse than anyone else. But the astute reader should take everything they read online with a grain....no a handful of salt.....unless you think the girl in this commercial has "got it all down".
http://www.youtube.com/watch?v=rmx4twCK3_I
More on the subject.....
http://www.theinquirer.net/inquirer/news/1024369/-usd-r...
http://www.washingtonpost.com/wp-dyn/articles/A3110-200...
http://www.fno.org/apr01/payola.html
http://www.dailytech.com/pay+to+play+uncovering+online+...
Score
February 7, 2013 3:52:29 PM
If you run high end cards you need a PSU with 700+v. Do the math.
Score
February 7, 2013 3:57:04 PM
For all the comments above that talk about big businesses creating networked monopolies:
The memory companies lying in bed together is nothing new either. They just got caught. From governments, to parent/child companies, to price setting, etc. It's happening everywhere. It's inevitable. It's greed and capitalism. There aren't strict enough penalties. Each person involved in scams should have ever dollar and belonging stripped away. They should be barred from ever starting another business. Forget prison. Take everything and give them no hope. Write THOSE stories in the paper. Then people might think twice before lusting after $.
Score
-2
February 7, 2013 4:20:06 PM
JonnyDoughFor all the comments above that talk about big businesses creating networked monopolies:The memory companies lying in bed together is nothing new either. They just got caught. From governments, to parent/child companies, to price setting, etc. It's happening everywhere. It's inevitable. It's greed and capitalism. There aren't strict enough penalties. Each person involved in scams should have ever dollar and belonging stripped away. They should be barred from ever starting another business. Forget prison. Take everything and give them no hope. Write THOSE stories in the paper. Then people might think twice before lusting after $.
Well... I think you missed the point of this article entirely.
Score
a b ) Power supply
February 7, 2013 4:31:36 PM
JackNaylorPEIf ya concerned about objectivity, ya might ask why the dollar categories for the Best GFX Cards each month change, shifting the boundaries up or down from month to month ? Ya might ask why the HD charts show speed rankings and yet the top units don't make it into their "Build for $xxxx" articles even though they the same price as the selected units. Is the selection influenced by the other News article that said "XXVendorXX" just sent us 10 Model ....." and they just happened to have 9 more on hand after doing the HD article ?Is this online payola, is it author bias, is it a Fox News kinda version of "fair and balanced" approach, is it an accuracy issue ? Is it simply a difference of opinion ? Who knows ? It' just makes one stop and ask "For what reason would they keep changing the dollar categories all the time ..... and when ya look, it usually falls out that when the $180-$210 category topped out at $220 last month, there's a $215 "winner" that got squeezed out of the category and is now competing with cards in the $210 - $250 range. Is there an attempt to favor one brand over another ? Or is the opposite true....is there an attempt to keep all players happy ?The worst instance of this I have ever seen is a PC magazine article from back in the mid 1990's. It probbaly didn't get a lot of attention from the gaming community as it as a database article. In the 12 categories, Microsoft Access garnered 7 excellent ratings and 5 good.....Lotus Approach garnered 11 excellent and 1 good. They TIED for Editor's Choice. I immediately imagined a Newspaper Headline ..... First Superbowl Tie Ever .... "New York Yahoos 33, Washingtom Wackos 15" !Yes, I still come here and do find the articles useful but I don't believe all of the articles are without "market" or "marketing" influences. For product selection, I'm not going to use a site that compared 5 PSU's or 5 GFX cards for a purchasing decision under one set of criteria and try and compare that with another article 3 months later with another 5. I'll rely on a site that provides a historical database of hardware tested that goes well into the double digits of units so I can make a valid comparison.Not picking on Toms .... not saying they are better or worse than anyone else. But the astute reader should take everything they read online with a grain....no a handful of salt.....unless you think the girl in this commercial has "got it all down".http://www.youtube.com/watch?v=rmx4twCK3_IMore on the subject.....http://www.theinquirer.net/inquire [...] dware-ranthttp://www.washingtonpost.com/wp-d [...] Apr19.htmlhttp://www.fno.org/apr01/payola.htmlhttp://www.dailytec... [...] le7510.htm
We've been told why the dollar amounts change each month. It is because pricing is constantly changing, so Tom's is trying to keep with the times instead of give us less relevant numbers. The Best for the money articles have nothing to do with what cards are sent by what companies because they don't rely on cards being sent by companies, they rely on performance data from many of Tom's tests and reviews.
Both getting editors choice doesn't mean that one isn't better than the other and is thus not comparable to something such as a Superbowl (I may not be much of a sports fan, but wouldn't a tie be settled by overtime or such anyway?). Tom's gave clear and logical reasons for their recommendations.
Score
-1
February 7, 2013 9:02:02 PM
Marcus52jonnyGURU is a place I go to for hardware tests as well, but I wouldn't put them above Tomshardware by any means. Frankly I think he showed a bit of leniency and bias in this article:http://www.jonnyguru.com/modules.p [...] y5&reid=32The article points out build flaws that I would have flat failed the unit for, stamping it with a big "DO NOT BUY" in red letters. Instead, he says it was a good unit that just didn't compete with the better products.I can easily see someone buying a Zeus because it's on for a sale price - "johnnyGURU said it was good enough, why not save some money?" Why not is because 3 years later those little ugly solder joints are going to come around to bite you in the behind. Mine took out my mainboard and CPU with it (after the 3-year warranty expired of course). Thanks, Silverstone.I didn't read reviews on the Zeus until after the fact because I trusted Silverstone. It was a bad move, and Silverstone is the reason I now tell people "Don't by just by brand, buy a PSU that you've read good reviews of." But if a site isn't very clear about the problems of a product, a potential user isn't going to be forewarned, and jonnyGURU is being a part of the problem here instead of the solution.Tomshardware was one of the first sites that starter testing computer PSUs - and telling us how bad they were. This site is in no small part responsible for the increase in quality we have seen in the last decade. Now, I do think Toms has changed a bit, not all for the better, and they are just as capable of being a bit biased or sloppy as anyone else, but jonnyGURU is NOT someone to hold up as a standard for PSU reviews. Yes, the site does a good job, but it doesn't do a great job.I'm not intentionally picking on jonnyGURU more than Hardwaresecrets or anyone else, it's just that the particular review of the Zeus stuck in my mind so I use that as an example. These are all good sites (If I had to talk "best quality" today I would say Anandtech.com; of course they aren't infallible either), but just like the PSUs themselves, you have to read them with a clear head and open eyes and pay attention to the details. So, like, I know that if jonnyGURU gives a "7.5" for build quality, that means a "don't freakin buy if it's the last PSU on earth" in my book.
The review you linked wasn't done by Jonny or OklahomaWolf, who are the two main reviewers (and respected members of the PSU world). Jonny did do the review about the PSU you are so aptly whining about dying after the 3 year warranty period. It scored well, but that was 7 years ago. Power supplies have changed significantly and so have the standards in which we grade them by.
Score
February 8, 2013 3:18:55 PM
FokissedWell... I think you missed the point of this article entirely.
I think you missed the quote I was responding to.
Score
February 8, 2013 3:20:22 PM
JonnyDoughIf you run high end cards you need a PSU with 700+v. Do the math.
My point was explicitly that some people don't run multiple high-end cards that require that much power, and they might, for some unfathomable reason, decide they want a more efficient power supply. If you're SLIing a pair of 680s, of course you're going to go with a much higher wattage PSU, but at the same time I don't know why you'd be looking at an article that is only covering PSUs below your needs.
Score
February 8, 2013 10:46:38 PM
I agree, it would be nice to get 400w 80+ Platinum PSUs. With a 6-year warranty from a reputable company I'd probably spend $20 more and get one.
Score
a b ) Power supply
February 8, 2013 11:19:47 PM
JonnyDoughI agree, it would be nice to get 400w 80+ Platinum PSUs. With a 6-year warranty from a reputable company I'd probably spend $20 more and get one.
My only issue with Platinums at that low power point is that they hardly make any difference. It'll save what, three, four watts over a proper Gold? Added reliability and warranty, I can understand those, but being a platinum at that point is like arguing the advantages of a 100MHz speed boost on a CPU that's already well beyond 3GHz. It's little more than a buzzword in such a situation.
Score
February 9, 2013 6:44:19 AM
It's 8 watts, and that's per hour. Over the lifetime (say 5 years) of use that's quite a bit of electricity my friend. At $20 it would be worth it, if for no other reason than to minimize the environmental effect of using more energy.
Score
a b ) Power supply
February 9, 2013 6:56:57 AM
JonnyDoughIt's 8 watts, and that's per hour. Over the lifetime (say 5 years) of use that's quite a bit of electricity my friend. At $20 it would be worth it, if for no other reason than to minimize the environmental effect of using more energy.
It's not likely to be anywhere near eight watts and that's not a lot of electricity even over five years. It's not going to impact the environment positively at all (not that there's anything wrong with wanting to help the environment, but the added electricity used to make the more complex PSU components will be greater than any power that you save through it) and its not even going to amount to $10 of electricity saved unless you have huge power bills.
Like I said, it'd pretty much just be a buzzword. A platinum would make a much bigger difference in PSUs around or well over 1000W in systems where the power consumption is high enough that the small efficiency improvement will make a considerable difference.
Score
a b ) Power supply
February 9, 2013 8:51:18 AM
It is nice to learn Cooler Master is also doing great in some products of its PSU line.
Score
February 10, 2013 9:57:52 PM
BigMack70Oooooooooooooooh very nice! I love when more sites than just Jonnyguru do quality PSU reviews - I know they're a ton of work so kudos for breaking out that oscilloscope and bringing us the info!I still generally think that the price premium for Platinum over Gold PSUs isn't worth it, though - particularly on lower wattage units like these.
Or on any wattage, for that matter.
IMHO, 80 plus silver presents a fair compromise
Score
February 11, 2013 12:44:42 AM
youssef 2010Or on any wattage, for that matter.IMHO, 80 plus silver presents a fair compromise
I agree. Bronze seems to be the current standard for quality PSUs, but I would love to see that move into the silver. I'd love even more to have a price competitive "gold standard" but I think we might be a bit of a ways from that still. With more efficient PSUs comes higher manufacturing costs. People still try to skimp on a PSU so they are still able to sell cheap crap ones. :(
Score
February 14, 2013 2:27:59 AM
Quote:
nestled into a soft, velvet-like bag. Although it looked nice, we weren't big fans of the overpowering chemical smell the bag was emitting.
i'm guessing some one enjoys the chewy treats of protein that crawl about and breed like rabbits every one else refers to cockroaches. i have a washer machine that cures that problem, works on dirty clothing also.
i always find it refreshing to smell that bug killer in a new refrigerator. i can rest easy knowing it's not a roach motel and source of infestation.
Score
      • 1 / 2
      • 2
      • Newest
