Card help
WHICH WOULD BE THE BETTER GRAPHICS CARD?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161372&Tpk=HIS%20Radeon%20HD%206950%20Turbo%202%20GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161368
I LIKE THE SECOND BETTER BUT IM A COMPUTER BUILDING NOOB dont worry abt rest of my system i just need help on this
44 answers Last reply
More about card help
  1. The only difference is the factory OC on the second one. You could probably OC the first one to the same speeds as the second, but the factory OC cards are generally guaranteed to be stable at those higher clocks, and may have higher headroom when overclocking.
  2. Also, the factory OC one has a non-reference cooler so it most likely has better cooling performance.
  3. So, the second ones better?
  4. the one with the sword on it?
  5. Oops I got those backwards, the first one is the factory OC one. The more expensive blue one is better in terms of factory speeds.
  6. Also, what system are you putting this in? What is your power supply brand/model?
  7. these are the differences i saw thats why i asked which i should get
    1st 1
    Effective Memory Clock
    1280MHz (5.12Gbps)
    Core Clock
    840MHz
    2nd 1
    1250MHz (5.0Gbps)
    Core Clock
    800MHz
  8. tower:Rosewill THOR V2-White Edition tower
    power:Rosewill Xtreme Series RX750-S-B 750W Continuous @40°C ,80 PLUS Certified, ATX12V v2.2 & EPS12V v2.91, SLI Ready CrossFire ...
    Ram:
    500658-B21 - HP 8GB (1X8GB) Dual Rank X4 PC3-10600 (DDR3-1333) Registered CAS-9
    times 4
    mother board: Gigabyte A75M-UD2H AMD Socket FM1 for AMD Llano CPU, HDMI, Dual Graphic Micro ATX Motherboard
    processor: AMD A8-3850 Llano 2.9GHz
  9. Yeah, the only difference is the first one has a factory overclock (OC), which means it's faster at stock settings. Although you can overclock the second one to 840mhz and 1280mhz, the first one will generally be more stable at those clocks. Also, the first one has a better cooling system on it compared to the second, which looks like a standard cooler.
  10. and a 160 gb ssd hard drive for the OS
  11. 750w is plenty for a single 6970, you are good to go.
  12. one more ques will this ram work in my board?
    times 4
    i know it will take the gb amount i just want to be sure im not buying incompatable parts
  13. 8gb RAM sticks are extremely expensive, you are better of going with 2x 4gb for much cheaper. Something like http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314 will do well. Also, you can add another set of these at a later date if you need 16gb of RAM.
  14. i like the 32gb they are $95.41 a stick x 4 =381.64 + $6.16 shipping
    i didnt think that was bad as long as they will work in my board
  15. $380 for 32gb of RAM is only reasonable on a pure workstation system. On a gaming system, even 8gb is overkill at the moment, so 16gb will last you a long, long, long time.
    So $380 for 32gb of RAM which you probably won't even use a quarter of.
    or $90 for 16gb RAM which you will probably not ever fully use in the next 5+ years at least.
    or $45 for 8gb of RAM which you won't fully use for a couple years from now at least.
  16. you can think about choosing gigabyte for the fans and heat dissipation
    http://www.newegg.com/Product/Product.aspx?Item=N82E16814125385
  17. ill take your opinion on ram into consideration but you didnt answer wether it is compatable with my board
  18. the gigabyte is a bit too costly compared to the one i have selected my tower has great cooling capabilities
    my current system is running a nvidia fx 5500 256mb scary hua?
  19. im only putting about $1500 into this computer
  20. Yes, basically all DDR3 RAM is basically compatible with your motherboard, doesn't matter the brand.
    A Nvidia FX 5500? So is this a workstation PC or a gaming PC, I'm still not sure...
  21. the nvidia fx 5500 is what i have now it was a gamiing machine in its day im building a new system from the ground up
  22. no it is the scary older one
  23. so im due for this upgrade
  24. not bad but iv spent the last 3 months researching what i want
    power:Rosewill Xtreme Series RX750-S-B 750W Continuous @40°C ,80 PLUS Certified, ATX12V v2.2 & EPS12V v2.91, SLI Ready CrossFire ... 89.99
    Ram:
    times 4 380.00
    mother board: Gigabyte A75M-UD2H AMD Socket FM1 for AMD Llano CPU, HDMI, Dual Graphic Micro ATX Motherboard 94.99
    processor: AMD A8-3850 Llano 2.9GHz 139.99
    about 300 in graphics
    160gb ssd 120.00
    640gb hard drive 45.00
    blue ray burner 67.99
    monitor 59.99 (22inch)
    speakers bose companion 2 49.99
    tower 169.99
  25. pluse keyboard mouse headset
    34.99
  26. If you want to waste $380 on RAM then by all means it's your money, but you could upgrade your 6970 to a 6990 or 2x 6970 by getting 8gb now and 8gb later, and I guarantee you won't notice any difference between 8gb and 32gb in a gaming system. But you will notice a significant difference between a 6970 and 6990, or 2x 6970 in crossfire.
    Also, the motherboard you picked won't run dual graphics cards very well, it only has 16x/4x PCIe lanes...not to mention it's a micro ATX board. You do realize you're putting a micro ATX board in a full tower case right?
    You should take some more time to research mate :)
  27. the processor runs as a dual graphics card and yes i know thats a micro board
  28. AMD Radeon Dual Graphics
    AMD Radeon Dual Graphics combines two powerful AMD Radeon graphics processors to dramatically boost graphics and gaming performance. Get the power of two when you add a qualifying AMD Radeon discrete graphics card for the most extreme visual and gaming performan
  29. would this be a better board?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131784
    or what board would be best for the processor i want in the tower?
  30. That board is only compatible with an AMD fusion APU. For a high end $1500 build you don't want an APU. Like I said, check the links above for a good $1500 build, because you're way off in left field at the moment, no offense.
  31. my processor is a apu
  32. Then sell it and get a real $1500 computer.
  33. what the apu no good?
  34. and what is the best full size board for the apu?
  35. Again, good $1500 gaming builds are in those links.
  36. i am anti intel the last 3 intel processors i bought were defective i wont have anything to do with intel
  37. Intel is the best at the moment, so I can't recommend a gaming build with an AMD CPU for $1500. Very few of the new Intel chips are defective.
  38. i had 3 in a row a few years ago i ordereda pentium 4 and had to return them twice after that they all fcked up it finally worked on the fourth processor ever since i avoid intel
  39. well thanks for the help
  40. No problem, good luck!
Graphics Cards Computer Graphics Product
