Solved
OCZ ZS Series 750W Performance Power Supply
Last response: in Components
I plan on putting together a computer that I can use for work but can also handle most games at decent settings. I'm considering to get the OCZ ZS Series 750W Performance Power Supply. Below are its specs:
This is my build overall with links for more specifications:
Motherboard: Asus P8Z68-V LE ---> http://www.memoryexpress.com/Products/MX34705
Processor: Core™ i5-2500K ---> http://www.memoryexpress.com/Products/MX31557
Video Card: HIS Radeon HD 6870 1GB GDDR5 PCI-E ---> http://www.memoryexpress.com/Products/MX35404
Power Supply: OCZ ZS Series 750W ---> http://www.memoryexpress.com/Products/MX34738
Chasis: Antec Three Hundred Versatile Mid Tower Gamer Case ---> http://www.memoryexpress.com/Products/MX20934
RAM: GSKILL Ripjaws X Series 8GB PC3-12800 Dual Channel DDR3 Kit ---> http://www.memoryexpress.com/Products/MX33234
HDD: Seagate 500GB Barracuda 7200rpm SATA III w/ 16MB Cache ---> http://www.memoryexpress.com/Products/MX35469
Optical Drive: ASUS DRW-24B1ST 24x DVD-RW Drive, SATA ---> http://www.memoryexpress.com/Products/MX27707
I want to know whether the above listed PSU is a quality unit that will last me a good number of years. Also, is it compatible with the rest of my build? Please comment.
If you prefer another PSU please refer from here: http://www.memoryexpress.com/Category/PowerSupplies
Thanks in advance
I have a Power PC and Cooling Silencer 750 (PP&C was bought by OCZ) and I have been hammering it for years and it has been flawless. I wouldn't shy away from an OCZ product, especially if they are utilizing PP&C components. They always have the beefy 12v rails and dead quiet with good 80%+ ratings.
Best solution
http://i46.tinypic.com/jie6aw.jpg
Thanks in advance
it's a good budget unit and has been well reviewed by several web sites. you would have enough power to run two AMD 6870
http://www.techpowerup.com/reviews/OCZ/ZS_750W/9.html
http://www.hardwaresecrets.com/article/OCZ-ZS-Series-65...
Related ressources
I've never heard anything bad about OCZ power supplies, other than people who have never owned one conjecturing about how they wouldn't trust them as much as Seasonic or Antec.
For my own part, I've used several, including the one powering this machine right now, and never had a problem with any.
Ask the community
