Hi,
I am running a SLI setup with a MSI TF 580GTX and an EVGA stock 580GTX. My mb is an Asus P6X58D-E with an i7 950. 12gigs of corsair dominator DDR3 1600 and a XFX 850W Black Edition PSU. It's all in a HAF X case with all fans installed.
The cards are in slots 1 and 2 on my mb. Idle temps are GPU1 40-42 and GPU2 45-47. When running them at load (Crysis 2), the MSI, which is in slot 1 closest to the cpu, hits temps in the low to mid 90s (I've seen it hit 98). I'm no pro, but this must not be good. The second card may peak at about 75C, which to my understanding is acceptable.
I have a custom fan profile set up, but now sure if it's really doing anything. Can I get MSI afterburner to run fans greater that 85%?
I attempted to move the second card to the 3rd PCI-E slot, but was unable to fit it in there because of the cable connections on the edge of my mb. I couldn't get it to click into the slot.
Does anyone have any suggestions on what I should do next? Would love to buy an new MB, but can't because money is an issue right now.
Thanks in advance.
Thanks in advance.
