Need to build a power efficent desktop for gaming
Hi i'm writing this because i need advice on how to build the most power efficent gaming system known to man ....
it should be able to play Mass effect 2 and also HOI 3 .....
i need the parts to be quality ... cost is not an issue , so i need a super efficent power supply unit .
5 answers Last reply
More about need build power efficent desktop gaming
  1. Antec Earthwatts 550W 80PLUS Platinum will do and any Intel Sandy Bridge CPU and a Radeon HD 6850 GPU this is the most power efficient gaming setup on the planet one that actuality games competent that is.
  2. ok, If cost isn't a prob go with this PSU :
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207019&Tpk=XFX%20Platinum
    It's Platinum 80+ Certified.
  3. Fill out the form hellfire posted
  4. purchase date end of febuary , around march maybe , after tax time ...
    budget range 1300 max
    system usage , gaming , video , internet
    parts not required , keyboard , i NEED low power LED montior , at least 24 inches ..
    parts preference INTEL
    country , USA
    overclocking no
    no crossfire or sli
    monitor resolution : 1920x1080
    other comments : i don't want a 1000 watt powersupply unit , below 500 should do the job ... i'm not interested in anything like a 6850 ,... i want POWER SAVINGS and a 6850 sucks down like 150 watts ...
Homebuilt Gaming Build Power Systems Product
