javier27 Honorable Apr 26, 2012 3 0 10,510 Apr 27, 2012 #1 Hello, I want to buy a thermaltake v5 case, and i own a amd 955 and a cooler master hyper 212 evo, i like that cooler but i need to know if the V5 has the enough space. Thank you.
Solution WR2 Apr 27, 2012 Hello javier27; Yes it will. NewEgg customer reports says a Thermaltake Frio @ 165mm tall fits in that case. The Hyper 212+ @ 158.5mm should fit just fine.
WR2 Polypheme Nov 18, 2005 27,923 6 61,960 Apr 27, 2012 Solution #2 Hello javier27; Yes it will. NewEgg customer reports says a Thermaltake Frio @ 165mm tall fits in that case. The Hyper 212+ @ 158.5mm should fit just fine. Upvote 0 Downvote Solution
javier27 Honorable Apr 26, 2012 3 0 10,510 May 25, 2012 #3 Thank you, i have bought the TT V3 and fits well, thank you for your answer. Upvote 0 Downvote
javier27 Honorable Apr 26, 2012 3 0 10,510 Jun 4, 2012 #4 Best answer selected by javier27. Upvote 0 Downvote
