Alright, I will try to keep this as short as possible. I had my 2500 oc to 4.6ghz and was running a 30 pass max stress test on IBT. When I came home, the pc was off. I turned it back on and messed around a bit. I noticed I had a constant load on core 0 of around 8-20 percent. In performance monitor I see it as a "system interrupt - deferred procedure calls and interrupt service routines" It is at a constant cpu usage. What is worse, is that this is keeping my cpu from downclocking to save on power.
To make matters worse, I tried updating my BIOS in hopes that would solve my problem...nope. P8P67 Pro will not read the bios and says something along the lines of it doesn't match current bios. That seems to be a common problem throughout the google-verse though.
I have re-installed my video driver, sound card driver, chipset, usb 3.0, and even tried unplugged all usb devices.
Is it possible IBT damaged my CPU? Temps were always 80 or below and only for bench marking for stability. I have done everything but wipe my ssd and start fresh. That however is a very long and daunting task, it has also been ineffective for a majority of the people I have read about with this problem.
I am at a complete loss. Please help!
