Approximate Purchase Date: Hopefully ordering the parts by the first of next month
Budget Range: about 1200
System Usage from Most to Least Important: Gaming, music preferably at the same time
Parts Not Required: Case or PSU, already purchased an NZXT phantom and
http://www.newegg.com/Product/Product.aspx?Item=N82E16817812012
Preferred Website(s) for Parts: Newegg or any competing site, if there is a fry's electronics deal i would totally hit that up too
Country: good ol USA
Parts Preferences: Intel and Nvidia+SLI
Overclocking: Yes in the future
SLI or Crossfire: Yes in the future
Monitor Resolution: right now its going to be something low but my goal is to get a 1920x1080 monitor, possibly 2 eventually.
Additional Comments: The one part of the computer i've been confused on and need the most help on is the motherboard. Specifically im concerned that with my current selection, i will bottleneck my GPU's when i go to SLI, if anyone could clarify that would be great.
Mobo: Need lots of help on this
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131806
CPU: Im pretty set on this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
GPU: Not right away but eventually i would like to x2 this.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127608
RAM: Not sure how the frequency plays in with the mobo
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311
Hard Drive: I plan on adding a SSD in the future
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148697
CPU Cooler: Since there so cheap and when i buy im gonna wanna play around with clock speeds.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Thanks!
Thanks!
