Solved
5 GB out of 8 GB ram Hardware Reserved? please help
5 GB out of 8 GB ram Hardware Reserved? os win 8 32bit what can i do ?
4 answers Last reply Best Answer
More about hardware reserved help
  1. You can buy windows 64 bit. You can not use more than 4GB in total of RAM on a 32 bit OS. Some of that 4GB will be reserved and unusable.
    So you have about 3GB to use which is correct for a 32 bit OS.
  2. Best answer
    Its 32 bit. You need to get 64 bit to be able to recognize more RAM
  3. thnx guys i will buy 64bit os
  4. Best answer selected by gogo_10.
Memory Hardware RAM
