I'm doing a lazy/poor man's PC build, and was looking for opinions on how I can maximize my setup. Here is what I have purchased so far, so I would consider those factors set in stone:
Dell Inspiron 620 Case and Crappy Motherboard ------------- $318.00
Intel® Core™ i5-2320 (6MB Cache, 3.0GHz)
Seagate 500GB 7200RPM Hard Drive
Crappy Stock DVD Drive from Dell
2x 4GB AMD DDR3 1600 (PC3 12800) 240-Pin SDRAM -------- $24.00
Corsair CX430 V2 430W Power Supply -------------------------- $15.00
XFX Radeon HD 6870 2GB 256-bit GDDR5 ----------------------- $159.00
LITE-ON iHAS224-06 DVD Drive ------------------------------------ $18.00
_______________________________________________________
$534.00
I want to keep my total damages under $600, which leaves me with $64 dollars to spend, give or take.
My questions for you guys are as follows:
1. Will all of this operate on my basic Corsair CX430, or do I need to be concerned? It was tough to pass up for $15.00, and I don't want to return it. I will have to power one of the PCI-E plugs on the graphics card with a 2 Molex to 1 PCI-E adapter. I've done a lot of research, and it sounds like it should work, but it may not be entirely recommended. I've used calculators and I'm fairly confident the wattage will come in short of the total 430W, but I only have 336W and 28A to work with on the +12V, and I'm not sure which of my other components will also be drawing from that. Any thoughts on this would be helpful. Will I need to remove the crappy stock DVD Drive, and is there any chance I will be able to use an additional PCI-E 1x card or a SSD?
2. I don't know anything about overclocking, and wasn't planning on it, but would it be possible to overclock my processor or graphics card in this system? I've been leaning towards no due to the fact that I'm running on stock Dell cooling and also am pushing the limits of my PSU, but if I could safely pull it off without wrecking things, I definitely would like to.
3. If I have the headroom, what are some useful and cheap PCI-E 1x addons; perhaps ones that wont pull power from the +12V rail?
4. I read in a review that this processor has "SSD Smart Cache Control"; what's that all about and why would it not pay to have over a 64GB SSD with it (that's what the reviewer said at least)?
$534.00
