I may decide to make myself a incredibly powerful computer with the following parts and need to know if would require liquid cooling and how powerful the PSU should be. Also would like to know if I need a different motherboard/if I should wait for Ivy Bridge. Lastly, do you have any recommendations for a fast SSD that still has a lot of storage space. I do not have a budget so you can recommend some ridiculously priced SSD's if you would like:
CPU: Intel Core i7 3960x Extreme Edition
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116491
Cost: 1050$
GPU: 4 x Radeon HD 7970
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127645
Cost: 2320$
Motherboard: Gigabyte LGA 2011 Intel X79
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128532
Cost: 270$
Memory: G.Skill Ripjaws Z Series 16GB (4 x 4GB) DDR3 2133MHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231503
Cost: 160$
CPU Fan: Phanteks 140mm UFB CPU Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709002
Cost: 100$
Sound Card: Xonar Essence STX
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132010&Tpk
Cost: 174$
Case: Silverstone Raven ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163135
Cost: 230$
PSU: Recommendations?
SSD: Recommendations?
Toal Cost Minus SSD(s) and PSU: 4304$
Thanks in advance
Cost: 1050$
Cost: 2320$
Cost: 270$
Cost: 160$
Cost: 100$
Cost: 174$
Cost: 230$
Thanks in advance
