Booting problem
Learn more about the CyberpowerPC Gamer Xtreme 1322 (GX1322)
General Spec
Brand
CyberpowerPC
Model
Type
Gaming
Processor
Intel Core i7 2600K 3.4 GHz
Processor Main Features
64 bit Quad-Core Processor
Cache Per Processor
8MB L3 Cache
Memory
8GB
Hard Drive
1TB
Optical Drive 1
24x DVD±R/±RW
Graphics
AMD Radeon HD 6850 1GB
Audio
Sound card - Integrated
Ethernet
Gigabit Ethernet
Power Supply
600W
Keyboard
Xtreme Gear USB Keyboard
Mouse
Xtreme Gear USB Mouse
Operating System
Windows 7 Home Premium 64-Bit
Special Features
Thermaltake Commander Gaming Case
Motherboard
Chipset
Intel Z68
CPU
CPU Type
Intel Core i7
CPU Speed
2600K(3.40GHz)
L3 Cache Per CPU
8MB
Graphics
GPU/VPU Type
Memory
Memory Capacity
8GB DDR3
Memory Speed
DDR3 1333
Memory Spec
4GB x 2
Memory Slot (Total)
4
Hard Drive
HDD Capacity
1TB
HDD Interface
SATA III
HDD RPM
7200rpm
Optical Drive
Optical Drive Type
DVD±RW
Optical Drive Spec
24x DVD±R/±RW DUAL LAYER DRIVE
Audio
Audio Channels
7.1 Ch Audio
Communications
LAN Chipset
Integrated
LAN Speed
10/100/1000Mbps
Front Panel Ports
Front USB
Back Panel Ports
PS/2
Rear USB
2 x USB 3.0
4 x USB 2.0
RJ45
1 port
Expansion
PCI Slots (Available/Total)
2x PCI-e x16
3x PCI-e x1
2x PCI
Pc powers on but won't boot properly. Led lights and fans come on but then it shuts down again. No beeps or anything....ideas?
1 answer Last reply
More about booting problem
    General Spec
    Brand
    CyberpowerPC
    Model
    Type
    Gaming
    Processor
    Cache Per Processor
    8MB L3 Cache
    Memory
    8GB
    Hard Drive
    1TB
    Optical Drive 1
    24x DVD±R/±RW
    Graphics
    Audio
    Ethernet
    Gigabit Ethernet
    Power Supply
    600W
    Keyboard
    Mouse
    Operating System
    Special Features
    Motherboard
    Chipset
    Intel Z68
    CPU
    CPU Type
    Intel Core i7
    CPU Speed
    2600K(3.40GHz)
    L3 Cache Per CPU
    8MB
    Graphics
    GPU/VPU Type
    Memory
    Memory Capacity
    8GB DDR3
    Memory Speed
    DDR3 1333
    Memory Spec
    4GB x 2
    Memory Slot (Total)
    4
    Hard Drive
    HDD Capacity
    1TB
    HDD Interface
    SATA III
    HDD RPM
    7200rpm
    Optical Drive
    Optical Drive Type
    DVD±RW
    Optical Drive Spec
    Audio
    Audio Channels
    7.1 Ch Audio
    Communications
    LAN Chipset
    Integrated
    LAN Speed
    10/100/1000Mbps
    Front Panel Ports
    Front USB
    Back Panel Ports
    PS/2
    Rear USB
    2 x USB 3.0
    4 x USB 2.0
    RJ45
    1 port
    Expansion
    2x PCI-e x16
    3x PCI-e x1
    2x PCI
    Let me ask you this. Did it work ever? And if it did. Did you happen to try overclocking the board or maybe the gpu. Try taking the GPU out and let the hd 3000 graphics load up if they can. And if it never worked out of the box. Try sending it back to the manufacturer.
Cyberpower Systems
