Hey all,
My new build is up and running, and seems to be doing just fine. Temps are in normal range, everything is running super smooth.
So far I've only had one problem, and it has me a bit worried. If I have my computer under significant load, i.e. during a gaming session, a quick clicking sound will start emanating from my computer. Once it starts, it continues consistently until I turn off the computer. The clicking is very rapid, maybe 2-3 clicks a second. I've put my ear to the comp to try and determine where the sound is coming from, and it seems to be right where the power supply is located. I'm using a CX600. Perhaps I should also note that my motherboard, a ASRock Gen3 Extreme3 Z68, had a bent pin for the HD Audio. I managed to carefully bend it back, and everything seems fine... just thought it was worth mentioning.
Once again, nothing else appears to be wrong with my computer, even once the clicking begins. Temperatures are normal, everything runs fine. I'm just worried that it won't be that way for long if I don't solve this issue. It only seems to start when I'm doing something demanding. It happened initially after the second boot, after playing FEAR (first game, not very demanding), and didn't happen again for a few days, even after hours of playing demanding games, until just recently after I OCed my GPU and started playing Crysis.
Any ideas as to what is going on here?
