First Time Builder..Will All These Parts Work Together?
Last response: in Systems
HI, I am about to order some parts for my first ever build, and would like an opinion on the parts I have chosen. I just want to make sure that everything will work together and that there shouldn't be any problems with the build.
Here are the parts
Intel i5 2500 3.3ghz processor http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Biostar H6 mgc motherboard http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Nvidia Zotac GTX 560 http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Raidmax Tornado ATX Case http://www.newegg.com/Product/Product.aspx?Item=N82E168...
PNY ddr3 ram http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Western Digital Caviar Blue 500gb http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Antec 500W power supply http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Logis card reader http://www.newegg.com/Product/Product.aspx?Item=N82E168...
LG dvd/cd combo http://www.newegg.com/Product/Product.aspx?Item=N82E168...
That's pretty much it... so yeah as a first time builder i'm just looking to know if all this stuff should work together and go together easily and your opinion on the parts as a whole. Also is there anything else I need to buy in order to put a system together?
Thanks!
Related ressources
They do, however since you are getting the i5 2500 (as opposed to the i5 2500k) your cores will be locked and the possibility of OCing is very limited.
Most people opt for the 2500k because they want to OC their processor and in doing so they need better cooling.. thus why they choose to purchase aftermarket heatsinks.
If you are not looking to OC, then you do not need to an aftermarket heatsink since the stock cooler that comes with the i5 works just fine at stock speeds.
Hi ive been planning on making a new gaming pc and ive pretty much collected all the parts. I am a first time builder and thats really all i need, I can still take some recommendations but id rather not have the price go up. The only thing iam wondering about is will all these parts go and work together and also with the current cpu cooler/heatsink i added how far from 3.3 speed can i go where it is still at a safe level that i wont feel worried with? here is the part listing: Here. Thx to everyone who replies. Also does the i5 cpu i bought come with a stock cooler?
Ask the community
