New Build Help
Just finished building my first computer, but have one problem.
When I start the computer, it goes to a screen, up top it shows the CPU temps and what not, but below that it says:
Reboot and select boot device OR Insert Boot Media and press any key.
Here are my specs, I am not sure how to enter the BIOS:
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813138324
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231223
HD: http://www.bestbuy.com/site/Western+Digital+-+Caviar+GP+500GB+Internal+Hard+Drive/8682311.p?id=1197679235869&skuId=8682311
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161377
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103871
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
Thanks :D
2 answers Last reply
More about build help
  1. Did you selected from BIOS ,first boot device HDD ?
    Not sure if you seen in my main post, I said I was not sure how to enter the Bios, I tried pressing F2,Del,etc..., but nothing.
Homebuilt Computer Systems Product
