Advice on if the hardware works well together? ~$2100
I don't know much about computers, but I've done some research and assembled what I would like to build. What I would love advice on is: do these various hardware selections work well together? I don't want to accidentally end up with a video card way more powerful than my CPU, for example.
This is a gaming computer, not for a whole lot else.
So, what I've got
Case: corsair obsidian 800d
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139001
Power: corsair AX1200 1200 watt is this is overkill on power?
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139014&Tpk=ax1200
Mobo: Asus maximus IV extreme-z LGA 1155 intel Z68 If i'm only gaming, do i need the Z68 chipset over a P67 or H67? Will that even be relevant?
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131760
CPU: Intel Core i5-2500k Seems like there's not a real big gain for the price point with the i7s
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Graphics: Radeon HD 6950 2gb, 840 MHz
http://www.newegg.com/Product/Product.aspx?Item=14-161-372&SortField=0&SummaryType=0&Pagesize=10&PurchaseMark=&SelectedRating=1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Keywords=%28keywords%29&Page=2#scrollFullInfo
RAM: Geil Evo Two 16gb DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820144567
Post-product heatsink: corsair H70 liquid CPU cooling
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181019
Harddrive: 120gb SATAIII SSD Seems like one of the more reliable SSD's on the market. I'll throw in a
couple more regular drives, but just this one to run on.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233206
Monitor: 23.6" 2ms 120 hz HDMI I would really like a 27" or 30", but i also want the 120 hz refresh and 2ms, which skyrocket the price of a larger monitor. Also, I'd like to keep everything looking as great as possible, and it looks like it takes a LOT more graphic card power to stay about 60 fps and looking good in games with the bigger monitors. What are people's thoughts on this?
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009222
4 answers Last reply
More about advice hardware works together 2100
  1. Unless you plan on adding another graphics card, the PSU is indeed overkill. This one will still do dual cards. http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
    The motherboard is also extreme overkill. This is one of the highest rated currently. http://www.newegg.com/Product/Product.aspx?Item=N82E16813131730
    Have seen reports that the 2gb model vid card benches lower than the 1gb version. This is a very good 1gb model. http://www.newegg.com/Product/Product.aspx?Item=N82E16814127604
    Ram also overkill. 8gb is sweetspot. http://www.newegg.com/Product/Product.aspx?Item=N82E16820231308
    Water cooling is your choice. But an air cooler would overclock nicely. http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
  2. Wow wow wow. Tons of overkill. You'll need 1000W MAX to power dual or even tri cards and 16GB RAM is excessive. YOu don't need 2GB of VRAM, save and get a 6950/70
  3. Also, the corsair Force is very slow, the Crucial m4 is better
  4. Thanks so much guys!
New Build Systems Product
