Approximate Purchase Date: Soonish
Budget Range: Approximately $1,500 (selling my laptop for +400)
System Usage from Most to Least Important: Gaming, Music, Videos, and Software Editing
Parts Not Required: Operating System, Keyboard, Mouse, and Speakers
Preferred Website(s) for Parts: Newegg or Microcenter
Country: USA
Parts Preferences: Intel CPU Nvidia GPU
Overclocking: CPU, RAM, GPU all when needed later down the line (3-5 years)
SLI or Crossfire: SLI in a couple of years when needed (only two way is supported)
Monitor Resolution: 1920 x 1080
Additional Comments: Performance is all I care about. It can run as loud as it needs to as long as I can still game with noise cancelling headphones on. Thanks in advance for any and all help!
CPU: http://www.microcenter.com/single_product_results.phtml?product_id=0354587
Note: I want this vs. a 2500k because I want the hyperthreding for video encoding which I am constantly doing.
CPU Aftermarket Cooler: http://www.newegg.com/Product/Product.aspx?Item=N82E16835118074
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118097
Note: I think the CNPS12X is overkill. What do you think. They both come with Zalmans special thermal paste (ZM-STG2), it looks good, but should I pick up for arctic cooler? (for the LED's read down to the Case Fan section.)
Mobo:http://www.microcenter.com/single_product_results.phtml?product_id=0366668
or
http://www.microcenter.com/single_product_results.phtml?product_id=0378090
Note: Like I said above I will be running SLI eventually, and am wondering if the gen3 three will help any bandwidth problem because the cards will have to run in x8? If so I will not be waiting for 6xx, so there would be no reason to go gen3.
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231476
Note: Typical question, is speed 1600 with cas 8, and voltage 1.5 better or speed 2133 cas 9, and voltage 1.65 better? Keep in mind the mobo supports both models and that I will be OC'ing eventually. Also will the support another 8 gigs of the same model?
SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227706
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227714
Note: I have heard that both of these are unstable, but it is worth the speed to me. I will eventually be buying another to RAID 0. Do I need the MAX IOPS edition?
HDD: Not buying right now because of the flooding. I have a 1.5T external that can hold me over. I will eventually be wanting to RAID 4 drives that have two running like RAID 0 and the other two backing them up simultaneously. What is this called? I think its' RAID 10, but I'm not sure.
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127578
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130651
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127565
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130623
Note: I have to decide if I wanna take a risk with MSI or stay say with eVGA. I'm looking to eventually OC and SLI, so what I'm thinking is that the factory OC'ed card don't matter because I can OC them myself, instead I am looking for the card that can provide the lowest temps at say Core Clock: 1000MHz and Shader Clock: 2000MHz. Which card do you think can maintain the lowest temps? Do you think I should just cut $$ off and go with eVGA's card similar to NVIDIA's reference card?
DVD Burner: http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106335
Note: The only real question is, is lightscribe worth the extra cost of the special DVD's? Other than that I don't plan on doing much else with the drive.
Wireless Adapter: http://www.newegg.com/Product/Product.aspx?Item=N82E16833166051
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166038
Note: Given the PCI slots on either Mobo's I will have one PCI Express slot, one PCI slot, and one PCI Express 2.0 x4 free. Eventually I will want a sound card for the PCI Express, and a RAID controller in the x4 slot, so I figure that getting an or adapter for the PCI slot isn't a bad idea. What would you do? (three antenna look cool)
Card Reader: http://www.newegg.com/Product/Product.aspx?Item=N82E16820300608
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223108
Note: I don't really care I Just need a card reader that does what its' supposed to do, and isnt obnoxious.
Case: http://www.microcenter.com/single_product_results.phtml?product_id=0361139
Note: Personally I think that this case look kinda badass. I you can find anything cheaper with the same or very similar spec by all means show it to me!
Case Fans/Fan Controller: http://www.newegg.com/Product/Product.aspx?Item=N82E16835209011
Note: (This ties in the the Kingwin PSU's and the CPU Coolers) I have talked to a lot of people about this and the general consensus is that there is no easy way to have a on/off switch on a fan controller. Is this true? I so, what would be the best way if at all possible to do this or mod something to do it? If I am missing something and someone could like me to a fan controller that could do this that would be great! Less importantly, but equally as cool, is there anyway of also controlling the LED's in the PSU ans CPU cooler all on the same switch as the case fans? That would be sooooo cooooooool!!!!!!!!
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817171049
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171048
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121075
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121076
Note: Basically now you know all of the components that I will have. So the question is, do I need 1000 watts or is that too much? I think it is, but everyone keeps telling me not to skimp out on the PSU. I Like the LED's in the Kingwin models but have the same problem listed in the Case Fan section above.
Monitor: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236153
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236102
Note: +5$ for EPEAT and 50,000,000 vs 10,000,000 ASCR. I think the cheaper ones is better. Am I wrong?
Finally, Surge Suppressors: http://www.newegg.com/Product/Product.aspx?Item=N82E16812107141
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16812107196
or
http://www.newegg.com/Product/Product.aspx?Item=N82E16812107131
Note: I just need to know How many Joules I need. Also My 200 watt speakers will be routed on the same strip. Which one fits me?
General Questions: Are there any conflicting parts? Is there anything I need that I don't have, or anything that I really don't need?
So, I know that was really long! If anyone could answer any of my questions that would be great!
Country: USA
or
or
or
or
or
or
or
or
or
or
or
or
or
or
or
or
