Alright, I'm going to try and do this by the 'book' and answer all questions up front right away about what you'll be 'working with'. This build is not complete [hence the help request]. I'd also like to ask to please refrain from asking me why I bought one item over another. I'm almost positive that what I've bought here will make no sense to some and I'm also sure that if I had asked for help in the beginning, I could probably have saved a few hundred hairs.
I bought this all in anticipation of building a new computer because [strike]I've finally landed a job where I can afford it[/strike] [irrelevant personal reasons] and its my first one.
I take full responsibility for being a dumbass should anything go wrong.[:fisshy:2]
■Case: COOLER MASTER HAF 932 Advanced (Dimensions: 22.70" x 9.00" x 21.50") (Cooling: 1 x 140mm rear fan, 1 x 230mm front red LED fan, 1 x 230mm top fan, 1 x 230mm side fan)
■CPU: AMD Phenom II X6 1090T
■Motherboard: MSI 890FXA-GD70
■RAM: G.Skill Sniper [2x4GB]
■PSU: Corsair CX600 V2
■APPROXIMATE PURCHASE DATE: I want to make this purchase as soon as I can. This week would be ideal but I'm not sure how Black Friday/Cyber Monday deals fare for video cards so let me know upfront if I should hold on till then for your recommendation.
■BUDGET RANGE: (e.g.: USD $150-250) [Before / After Rebates]: Honestly, thats a tricky question right now since I'm looking at an SSD as a boot [Crucial M4 64GB @ $119.99] so around $150-$200 ($250 MAX) Before rebate please.
■USAGE FROM MOST TO LEAST IMPORTANT:
1 - Blu-Ray movies hooked up to my TV through HDMI
2 - Gaming. I'm not going to be playing a massive amount of games [Skyrim, NBA 2K series & POSSIBLY the Mass Effect series to name a few] to start but I do want to be able to play those on the highest settings where possible.
3 - Adobe CS Master Collection/Video Editing
■PREFERRED WEBSITE(S) FOR PARTS: None. Wherever you're able to find one with least amount of shipping works for me.
■PARTS PREFERENCES: Honestly, I've looked at both nVidia and AMD/ATI to find differences in features and I couldn't tell you one way or another which one is superior. Whichever works best with my setup/usage. Brand-wise, I'd like to keep it in the area of MSI, XFX, Gigabyte or ASUS if possible. If not, no big deal.
■OVERCLOCKING: MAYBE. I'm still on the fence on whether I want to crank up the card to 11 so by all means, if you've got a reason, let me hear it.
■MONITOR RESOLUTION: Another tricky topic. I'm currently on an ACER AL1916W with a supported resolution of 1440x900@75Hz but again, I'm also going to be hooking up to my TV with a supported resolution of 1920X1080 through HDMI. I plan on upgrading my actual monitor in time but for now this will unfortunately be what I work with.
Hopefully this gives you guys/gals a pretty good idea of what I'm working with and what I want to do. I will answer any/all questions the best I can. Thank you for your help.
