Power supply failure, Need advice on a new one
  • Power Supplies
  • Computers
  • Power Up
  • Components
  • Product
Last response: in Components
April 29, 2012 4:16:07 PM
A week ago there was a loud bang from my computer and now it fails to power up. What are the chance that the components would have survive the power supply overheating?
I could do with some suggestions about a replacement 600w power supply, don't really know which brands are the best.
More about : power supply failure advice
a b ) Power supply
April 29, 2012 4:44:20 PM
without installing a new PSU, there is no way to tell if other components where damaged. stick to brands like pc power and cooling, antec, corsair, ocz, seasonic, nzxt, enermax, silverstone, and xfx when shopping for new PSU.
some recommendations
good
better
m
l
a c 158 ) Power supply
April 29, 2012 4:50:36 PM
He could try swapping the components into another PC...at least that would work for the GPU, aux cards, and disk drives. Not so much for the mobo/cpu
m
l
April 29, 2012 4:52:53 PM
Cheers, would a 600w power supply be strong enough to run a new gaming computer if I dont plan on using sli?
m
l
a b ) Power supply
April 29, 2012 4:56:43 PM
or just swap that PC's PSU into the old build rather then removing mobos, add on cards & HDD
m
l
April 29, 2012 4:57:14 PM
I was going to try that with my graphics card, but I was told to get a 600w power supply for a 250gts and the only other power supply I have is a 250w from a 10 year old computer.
m
l
a b ) Power supply
April 29, 2012 4:59:51 PM
depends on the video card but a quality unit like the pc power and cooling 600w unit will run any single GPU card like the nvidia GTX 570 & 580.
m
l
a b ) Power supply
April 29, 2012 5:02:18 PM
you can run the GTS250 with a quality 400w+ unit (28a+ on the 12v rail). a quality 600w unit will run two GTS250. as long as you don't install your video card, the 250w PSU can power your cpu & mobo just to see that they are fine.
m
l
April 29, 2012 5:10:13 PM
So If I put the old power supply in my computer and connect it to everything but the graphics card it should work? or do I need to remove the graphics card from the motherboard?
m
l
a b ) Power supply
April 29, 2012 5:50:59 PM
remove the card and connect the monitor to your mobo's video output
m
l
