Solved
New Pc build need help
Hey gang i am building a new Intel build and I have a few questions. I have the old aging Comos 1000 I need help with what size power supply to get as in SIZE. This case is pretty big but doesn't fit those massive power supplies at all. I need like a good Crossfire/sli 1000w psu that will fit in the Comos 1000.
Next up is I am really unsure which way to go with Intel, i will have a budget of 3000$- 3500$. This build will have to be a hardcore gamer build and sadly as huge as my tower is it will have to be at max an sli or crossfire build as well. With all that said do i go with LGA 2011 Or LGA 1155. I do Web design on the side so the extra horse power of a 3930 would be nice. So what I need is a list of the very best within my budget of Motherboards for both sockets, Ram, PSU, CPU, and maybe even the best case for all this stuff if i can get it all into my Budget. Oh yeah and best Video cards for gaming if again they fit into my budget.
I really do not know much between the 7970 cards and the 680's. I don't care about Benchmarks just which ever is going to give me a lot of bang for the buck and also be budget friendly.
9 answers Last reply Best Answer
More about build help
    If you want to build in the next 1 month and overclock without heat issues, please go for Sandy Bridge.
    CPU is i7 3930K
    Mobo: Asus P9X79 Pro
    GPUs: GTX 680 (when in stock)
    RAM: G.Skills Ripjaws Z 8 GB but you may go for 16 GB if you are going to do a lot of design, video, photos.
    PSU: Seasonic X750
    HDD: seagate 3tb 7200rpm hdd
    SSD: Samsung 830 SSD
    Optical Drive: Your choice (LG)
    CPU Cooler: Noctua NH-D14 or Corsair H100.
    Case: Plenty to choose from.
    Intel has acknowledged that Ivy Bridge heat issues when overclocking. I think they would address it by probably changing their thermal packaging. If you do not want to build in the next 1 month, I would recommend the IVY Bridge as it is the latest top of the link CPU.
    CPU would be i7 3770K
    Mobo: ASROCK Z77 extreme 6....
  2. I agree with SSri if you take 1 GTX 680 - but if you choose 2 i say a 850W or 1000W
    PSU...
  3. SSri has suggested good components and I would add correon's suggestion of an 850 to 1,000 watts PSU - Corsair, Seasonic, Antec. Look into the modular PSUs (Corsair HX850, HX1050)
    This (HAF-X) is a great case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
  4. Best answer
    Corsair Carbide Series 500R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
    Item #: N82E16811139009
    Western Digital Caviar Black WD2002FAEX 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    Item #: N82E16822136792
    CORSAIR Professional Series HX850 (CMPSU-850HX) 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC ...
    Item #: N82E16817139011
    CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9
    Item #: N82E16820233143
    MSI X79A-GD45 (8D) LGA 2011 Intel X79 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
    Item #: N82E16813130635
    Intel Core i7-3930K Sandy Bridge-E 3.2GHz (3.8GHz Turbo) LGA 2011 130W Six-Core Desktop Processor BX80619i73930K
    Item #: N82E16819116492
    CORSAIR H100 (CWCH100) Extreme Performance Liquid CPU Cooler
    Item #: N82E16835181017
    ASUS Black Blu-ray Burner SATA BW-12B1ST/BLK/G/AS
    Item #: N82E16827135252
    Corsair Force Series 3 CSSD-F240GB3A-BK 2.5" 240GB SATA III Internal Solid State Drive (SSD)
    Item #: N82E16820233268
    Subtotal: $1,931.91
    THIS LEAVES ROOM IN YOUR BUDGET FOR 2 x GTX680s when there in stock.
  5. Or a single GTX690...
    Indeed !
    In fact this going by the initial 690 reports maybe the better option, cheaper too.
  7. Retail is looking like $1000; similar performance to SLI GTX680s, good OC potential, and less power consumption.
  8. Best answer selected by tool1523.
Power Supplies Build Components Product
