Need some help
I've been spending some time lately on the web reading and learning more and I think I've finally put my best build for my price range together, but I just want some feedback from some experienced builders.
Specs:
EVGA Superclocked GTX 560 1gb
Corsair Professional Series HX750 750W
Cooler Master Hyper 212 Plus
Cooler Master HAF 932 Full
G. Skill Ripjaw 8gb DDR3 1600
Intel i5 2500k
ASUS P8P67 Deluxe
Arctic Cooling MX-2 Thermal Comp.
Links:
GPU http://www.newegg.com/Product/Product.aspx?Item=N82E16814130661
PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
Cpu Cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Case/Ram combo http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.814641
CPU/Mobo combo http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.797219
I'm going to be doing some gaming and some overclocking.
Any feedback would be appreciated.
Thanks.
9 answers Last reply
More about need help
  1. Yes is a great build. Buy 560Ti is better than 560. 560 is an 460 overclocked and rebranded.If you don't SLI buy an 650W PSU is more than enough.
  2. Well, is 750w suffice if I do choose to go SLI in the future?
    Also is the 560 Ti worth the $40-$50 more?
    If I went with the 560 Ti, do you think I could just drop down to a haf 922 and still have enough room? This would allow me to stay within my budget (which is very strict).
  3. Also, would there be a better SLI configuration for around the same price?
  5. That psu is excellent and a good price too!
    Yeah the 560ti is a better choice and the 922 is huge for a mid-tower.
  6. +1 on the Haf 922 in fact I just finished a build for a friend and he used the Haf 912 which is at the base for the HAF series and even that case would work just fine and at a price of $59.99.
    I litterally just orded the haf 932 less than 5 minutes ago.
    I spent the last 2 hours in other forums and youtube for reviews and I chose the 932. It seems to be the best for air flow and if I want to upgrade to water cooling later on. I probably should've went for the 912, but I just go really excited and jumped on it. I only ordered the case, cpu cooler, psu, ram and thermal compound. Will have to wait until next month to get the rest.
    Thanks guys!
  8. LOL, no worries there will be no disappointment the HAF 932 is a suburb case.
  9. This topic has been moved from the section CPU & Components to section Systems by Mousemonkey
New Build Cooler Master Systems Product
