I just purchased a 9600GSO for my computer. I put it in and my monitor shows "No Signal". I thought it was my BIOS and it needed to be updated, but gateway shows there are no updates available for my computer.
The next question would be, is the card even compatible or is it a DOA?
Here are the specs:
Computer/Motherboard: Gateway DX4200 / Gateway RS780 (AM2)
Graphics Card: XFX GeForce 9500 GSO
Also, my MOBO could run a 8600GT, if that makes any difference.
I am running Windows 7 64Bit.
Here are the specs:
