Closed Solved
2x6pin Card using only 1x6pin
Hey so I wanted to buy an ATI Radeon 5850 which requires 2x6pin connectors to power the card, however, my power supply only has one 6-pin connector. Does this card REQUIRE 2 of the 6pin pci connectors to run, or as long as there is enough power going through the single connector it will still run?
Additionally I was wondering if my PSU can support the 5850. I currently have an Antec 430W green.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371034
Thanks!
6 answers Last reply Best Answer
More about 2x6pin card 1x6pin
  1. The card needs the two 6 pin to run properly. I suggest you upgrade your power supply to at least 500W.
  2. Yes the card would require both 6 pin connectors, your PSU isn't designed to power such cards, hence the single 6 pin connector.
    AMD recommend a PSU with atleast 500W, although your PSU is of good quality it just doesnt have the power for a HD5850 (+ The rest of your PC)
  3. Alright so follow-up question,
    I was looking at the 5850 due to its performance over the 6850, but the 6850 is more efficient and draws much less power. (And it also only need 1 6-pin connector)
    This should work with my PSU right?
  4. Best answer
    I'm pretty sure a 5850 is 151 watts. The PCI express slot supplies 75 watts, and a 6 pin PCI express connector supplies 75 watts. A better choice for your situation may be a 6850 which should be similarly priced with similar performance but uses about 30 watts less and only requires one PCI express 6 pin.
    You may be ok with purchasing a molex adapter and using that for the second connector
    http://www.amazon.com/StarTech-com-6-Inch-Express-Adapter-LP4PCIEXADAP/dp/B0007RXDDM/ref=sr_1_1?ie=UTF8&qid=1321713329&sr=8-1
    usually one or two of these will be included with a new card anyways.
  5. I would rather have a 5850 personally, but with new DX11 games that do tesselation and stuff, the performance is pretty close with a 6850.
  6. Best answer selected by bozoisundead.
Graphics Cards Power Graphics Product
