Solved
Front headphone and mic jack won't work antec 900
Last response: in Components
April 30, 2012 7:55:22 PM
Hey guys I have windows7 and when I go to my sound card options the headphones option always says that there is no device even though I have my headphones pluged into the front 3.5mm green jack that is listed in headphones. Any ideas?
P.S. I tried updating drivers.
April 30, 2012 8:12:10 PM
Did you put the PC together yourself? I'm assuming the front audio jack ins't plugged in right on the interior connection.
m
l
a b $ Windows 7
April 30, 2012 8:17:08 PM
right-click on speaker at bottom right
right-click on all the options there and on test
my headphones come under there as speakers (it is through a pass through attached to keyboard)
m
l
April 30, 2012 11:10:39 PM
I did put it together myself. I even have a few cords loose from the case haha so they are probably the problem. For the most part I did a good job, I got everything to fit and work nicely. The wires left over are labeled HD audio (my brother in law said you needed a sound card for that, I personally don't know) then there is the restart button (I plugged this into every available spot on my mobo and it never worked but honestly I would never use it even if I could so I don't care about it). As for the HD audio wire I really don't think there are any places I can put it. I looked for a very long time and couldn't find the correct spot for it.
m
l
April 30, 2012 11:13:57 PM
Right mine shows up as headphone but even though they are plugged into that slot it says "Not plugged in"
m
l
Best solution
May 2, 2012 3:58:49 AM
Your mobo's manual will have a guide as to where to plug everything in. Plugging them into the wrong places might cause some damage. And the HD audio wires are why your headphones don't work, they run from the mobo to the headphone jack on the front of your case.
May 2, 2012 4:00:37 AM
That Makes sense. There really is no place for that cord though. I'll look it over again but there is nothing I can find.
m
l
May 2, 2012 2:31:07 PM
/facepalm
Ok I found it.
Now that I have it working the audio sounds great through it however I can hear this light highpitch sound.
It almost sounds like I can hear the mobo operating lightly in the background.
m
l
May 2, 2012 5:08:33 PM
omgomgpie said:
/facepalm
Ok I found it.
Standard issue with onboard sound for the most part.
m
l
May 2, 2012 8:00:44 PM
Well thank you guys very much!
m
l
May 2, 2012 8:01:09 PM
Best answer selected by omgomgpie.
m
l
