Cooler noise
Just a quick question, what is the best fan for an fx-8150. I am not planning to overclock and i just want to have a silent but powerful pc.
2 answers Last reply
More about cooler noise
  1. What is your budget? If you want silence, anything by Noctua will serve you well! However, you can go with a cooler master hyper 212+ and replace the fans with silent fans! I prefer the Cougar Vortex 120mm fans!
  2. well, i was planning on getting a zalman z11 plus for a case. the cooler just has to be silent, the fans you suggested seem like some really good ones. I probably will use one of them but if you know any better ones please respond. It doesn't need to be all that powerful since wasn't planning to overclock.
Overclocking Cooling Fan Components
