Hi there,
First time poster here. I'm looking at upgrading my PC, which I use primarily for gaming (BF3, and MMO's). This is what I currently use:
CPU: AMD Phenom II x3 720
Mobo: Gigabyte MA790XT-UD4P: http://www.gigabyte.com/products/product-page.aspx?pid=3010#ov
RAM: 8 Gig of Kingston DDR2 800
GPU: Just got myself a Sapphire Radeon 9650 2 gig card: http://www.sapphiretech.com/presentation/product/?psn=0001&pid=1021&lid=1
SSD: OCZ Vertex 3 120 gig SATA III. It's currently plugged into a SATA 2 port though as that's all the mobo has. I have the OS (Windows 7 64 bit) and my primary game (SWTOR) on it.
HDD: 500 Gb Western Digital
Power Supply: 650W OCZ Stealth
Case: Antec 300 Gaming case
So I'm noticing some terrible frame rates with SWTOR specifically (17-20FPS when in a warzone). I thought that most of the work was done on the GPU, which is why I bought the 6950. Also, I'm not making best use of that SSD having it plugged into a SATA II port. So I'm looking at upgrading to a new platform, and would like to go back to Intel. Here's what I was thinking:
CPU: Intel i7 3820 coming out in Feb. I'd have loved the i7 3930k, but $655 is pushing what I would like to spend. I understand that the 3820 isn't much more in terms of performance from a 2600k, but I was thinking it would be good to get on socket 2011.
Mobo: I was looking at Asus, and just getting a x79 mobo in the $300'ish range.
RAM: I'd need to upgrade the ram to DDR3, and was thinking of 16 gigs using G.Skill quad channel kit (4x4gig).
I was going to keep my existing GPU, Powersupply, Case, SSD and HDD. I'm wondering though if a 650W is going to cut it, or should I be looking at something higher (only 1 graphics card, I'm not looking to SLI).
Any other thoughts on this upgrade path would be appreciated. Cooling perhaps?
Thanks very much.
Thanks very much.
