jhafner Distinguished Jul 24, 2011 200 0 18,690 May 1, 2012 #1 Hello; I have a 3 pin fan for cpu and i want it run on 24v, can i connect the 2 power wires to the adapter then connect the 3rd wire to the motherboard to monitor it's rpm via bios or speedfan ?! Thanks in advance for your help... Regards.
Solution popatim May 2, 2012 No the fan is designed for 12v, not 24...but the 3rd wire idea will work fine.
popatim Titan Moderator Dec 2, 2009 38,904 980 135,890 May 2, 2012 Solution #2 No the fan is designed for 12v, not 24...but the 3rd wire idea will work fine. Upvote 0 Downvote Solution
jhafner Distinguished Jul 24, 2011 200 0 18,690 May 2, 2012 #3 Best answer selected by jhafner. Upvote 0 Downvote
