Solved
Hd 7770 on cooler master extreme power 460
Last response: in Components
Best solution
Yes , it can run HD 7770 without any problems.
Quote:
Here is Guru3D's power supply recommendation:
Radeon HD 7770 - On your average system the card requires you to have a 450 Watt power supply unit.
Radeon HD 7770 Crossfire - On your average system the cards require you to have a 550 Watt power supply unit as minimum.
Ask the community
