Best power supply for emachine ET1810
i need help finding right power supply for my emachine ET1810
6 answers Last reply
More about best power supply emachine et1810
  1. Is there any add-in graphics card in it or plans for one?
  2. Your computer probably has a 200 - 250 watt PSU inside it. The problem is that most PSU's in that size are pretty cheaply built.
    Something like an Antec Earthwatts 380, although overkill, would work very nicely:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371033
  3. yes i added a geforce 210 g card a while back...what happend was there was a power outage not to long ago that occured while my pc was off.i tried powering it on after and no luck...it seemed that the previous 250 watter was doing its job of course until this power outage occured.iam on my ps3 right now.
    i just added a geforce 210
    this power supply will fit forsure in my pc
  6. Yes it will fit.
    I was going to suggest this one but the Antec delivers more power for the same price when you add in shipping. I'm just not a fan of Antec. I have these in several low power builds and all are doing great.
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151086
Power Supplies eMachines Components Product
