T th1rte3n Honorable Apr 26, 2012 14 0 10,510 May 2, 2012 #1 So im thinking of getting a geforce gtx480, and i have an i52500k and that psu, will it run it or do i need to buy another power supply. I just dont know for sure if it will hold everything including my rosewill blackhawk mid atx case. Please help.
Solution A A aicom May 2, 2012 I'm not sure about the quality of the unit, but if it can deliver its rated wattage, it should be plenty for your 480.
A aicom Honorable Mar 29, 2012 923 1 11,160 May 2, 2012 Solution #2 I'm not sure about the quality of the unit, but if it can deliver its rated wattage, it should be plenty for your 480. Upvote 0 Downvote Solution
T th1rte3n Honorable Apr 26, 2012 14 0 10,510 May 2, 2012 #3 Best answer selected by th1rte3n. Upvote 0 Downvote
vrumor Judicious Jan 17, 2012 7,749 1 35,015 May 2, 2012 #4 I wouldnt trust that PSU with a 480 and the rest of your gear. Upvote 0 Downvote
T th1rte3n Honorable Apr 26, 2012 14 0 10,510 May 3, 2012 #5 vrumor : I wouldnt trust that PSU with a 480 and the rest of your gear. could you recommend one im kindve lost with this. Upvote 0 Downvote
vrumor Judicious Jan 17, 2012 7,749 1 35,015 May 3, 2012 #6 Id get a good 750w Corsair, XFX, Seasonic or Antec EarthWatts, Upvote 0 Downvote
T th1rte3n Honorable Apr 26, 2012 14 0 10,510 May 3, 2012 #7 CORSAIR Enthusiast Series TX750 V2 so would this be a good pick then? and thank you for the help again. found it on new egg for about 85 Upvote 0 Downvote
vrumor Judicious Jan 17, 2012 7,749 1 35,015 May 3, 2012 #8 That would be a fine PSU for you. Good choice. Better to be safe than sorry when you are protecting your rig. Upvote 0 Downvote
T th1rte3n Honorable Apr 26, 2012 14 0 10,510 May 3, 2012 #9 Thanks for all the help going to begin buying everything tonight. Upvote 0 Downvote
