First computer, would like to know if parts I selected are compatible
Im looking to build a computer and am concerned that the components ive selected may not be compatible.
AZZA Solano 1000 Black/Black Japanese SECC Steel/Metal mesh in front ATX Full Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811517004
Western Digital Caviar Green WD7500AARX 750GB IntelliPower 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136950
EVGA 01G-P3-1561-AR GeForce GTX 560 Ti FPB (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130604
CORSAIR Professional Series HX650 (CMPSU-650HX) 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139012
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 2133 (PC3 17000) Desktop Memory Model F3-17000CL9D-8GBXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231476
ASRock Fatal1ty P67 Performance LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157253
Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Im mostly worried about two parts not being compatible with each other for some reason I cannot see. If im missing anything please let me know. also this is my first post, although i did read some newbie rules, but if ive formatted something incorrectly or broken some rules please forgive me
3 answers Last reply
More about first computer parts selected compatible
  1. I've heard bad things about caviar green... And i've only heard good things about seagate barracuda - 500gb for 85 bucks on newegg - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148767. You also may be better off with this mobo http://www.newegg.com/Product/Product.aspx?Item=N82E16813157271 but i'm not sure. But, to answer your question, yes, everything is compatible.
  2. the motherboard youve suggested says its pci 3.0 x 16, will that work with the graphics card?
  3. Change the board to a Z68 board. Preferably the Asrock Extreme3 Gen3. Other than that its fine. Oh and change to a cavier blue.
Homebuilt Computer Compatibility Systems Product
