Dedicated Ethernet/Wired vs. Onboard Ethernet
I just had a few questions for anyone that could help:
I'm about to build a new SFF PC ( That may be transported around place to place ) and I wanted to be able to get the best Wired/Wireless connectivity that I could get within my budget and I was just wondering IF:
-- Are there any noticeable performance gains from using a dedicated Ethernet card rather than using the motherboards Onboard Ethernet? --
Also, as far as enabling wireless connectivity for the system, is this a, quote, "good-enough" Wireless adapter: http://www.newegg.com/Product/Product.aspx?Item=N82E16833315091
I'd appreciate if someone could help me out with those questions!
Thanks!
3 answers Last reply
More about dedicated ethernet wired onboard ethernet
  1. For a wired card it only matters if you are pushing lots of traffic, need a certain feature set, or prefer a certain brand. Some brands are better (Marvell, Broadcom, Intel) than others (Realtek). Additionally, some do not play well with other operating systems other than windows.
    That wireless adapter should work fine, but I wouldn't expect much range or throughput out of it with an antenna that small.
  2. This is my opinion ,why wireless ..its quicker and easy to use but distance is *** ..if u are traveling ..are u talking bout LAN party's or a weekend away
  3. I find the best performance come from intel nic's (never tested one of these Killer brand gaming nic's) and they are cheap enough to warrant putting them in esp if you have a realtek on board.
NICs Wireless Connectivity Ethernet Card Components Product
