Hey,
Okay so I am upgrading my current computer. I want to be able to run all these components and SLI two GTX 460's.
Here are the parts.
1. MSI P67A-G43 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard ($100)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130583
2. Patriot Gamer 2 Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model PGD38G1333ELK ($36)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820220557
3. Intel Core i5-2500K Sandy Bridge 3.3GHz (3.7GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor Intel HD Graphics 3000 BX80623I52500K ($220)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
4. PNY VCGGTX4601XPB GeForce GTX 460 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card ($130)
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133428
I was wondering if this cooler would be good enough to overclock the i5 CPU to 4Ghz?
EVGA M020-00-000234 Superclock CPU Cooler ($50)
http://www.newegg.com/Product/Product.aspx?Item=N82E16835288001&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=129c1czlqwzhu
And will this PSU be able to run all of that? I know that I will need the 4 pin to PCIe connectors, I have them.
Antec EarthWatts EA-650 GREEN 650W ATX12V v2.3 SLI Ready CrossFire Certified 80 PLUS BRONZE Certified Active PFC Power Supply ($72)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371044&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1169w6dxjiidp
If that cooler is not good enough, which one could I get that's better for equal or lesser value. I have a mid atx case, so as much as I want a CM Hyper 212 Cooler, it wont fit. Same with the PSU, equal or lesser value, also I would prefer a PSU that isn't green ( have a see through side panel thing lol)
Anyway, thanks for your help!
Arlen10
Here are the parts.
Arlen10
