My case is a Zalman Z9 Plus and the side panel supports up to 2 140mm fans.
I found this adapter that allows me to put a 200mm fan in a spot for 120mm/140mm fans and am planning on buying 2 and putting 2 200mm fans in the inside of my case for optimal cooling and silence
I was wondering before i buy these if they will be too big, or not fit, and any other concerns I might take into consideration
ADAPTER: http://www.frozencpu.com/products/14953/duc-54/FrozenCPU_200mm_to_120140mm_Fan_Adapter.html#blank
FANS: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103073
CASE: http://www.newegg.com/Product/Product.aspx?Item=N82E16811235027&Tpk=Zalman%20Z9%20plus
