I'm currently looking into a computer build for video editing and slight gaming so I want to go for a 3x display.
I'd really like the 3 displays to be from 20-24 inches, so if you guys have any models to recommend me (with thin bezels), PLZ don't be afraid to advise.
Currently, I was going to set up 3 of these monitors:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824001475
with two of these GPU cards:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127582
But I have a few questions:
I most likely NEED 2 cards to connect the 3 monitors, correct? Two of these cards comes out to $740 so I am just wondering if I should get a 6990 dual GPU card for $730. Which option would provide the best performance?
Sidenote:
I will be getting an adequate power supply -- 1200W.
Sidenote:
