I recently built a new PC with Phenom II X4 955 BE. Currently I have fitted this system in my old cabinet with no front fan, only rear 80mm exhaust. I live in India and here temperatures range from 30'C to 40'C. Following are the CPU temperatures:
Idle: 38-40'C
on load: 59'C (62'C running prime95 for 15 mins)
I am using stock AMD BE cooler (with cooper pipes)
Is this Temp OK or it should be decreased?
2nd Ques. is I am going to buy a budget cabinet with front fan. (@ around $42) {Cooler Master elite 311}
If I get a cabinet with front 120 or 140mm fan with 120mm exhaust fan, will that decrease temperatures effectively with good air flow? Or I need a good CPU cooler?
I may be overclocking my CPU & adding a GPU in future (like HD 6770)
I am going to work on some CAD softwares, rendering, etc.
Specs:
CPU: AMD phenom II X4 955 BE (stock) w/ stock heatsink-fan
RAM: 4GB adata 1333mhz
HDD: 1TB seagate 7200rpm
MOBO: ASUS M5A88-M
PSU: Corsair CX430V2
Idle: 38-40'C
Specs:
MOBO: ASUS M5A88-M
