Hi everyone!
Problem...
Since day one I have been having difficulties with my new computer, specs are as follows:
CPU 2600k (O/C 4.5ghz)
2 x GTX 580 Superoverclock edition
12 gb ram
Corsair 1050HX
G1.Sniper2 motherboard
I'm hoping to get some clarification regarding Vysnc. If I disable Vysnc then I experience constant stuttering liken to that of frame skipping. I am able to get 80+ FPS with maxed out settings for games but without Vysnc it'll stutter. With Vysnc enabled however, the FPS is locked at 60fps and the game runs 'smoothly', eliminating all signs of stuttering.
I am curious to know if my monitor (Samsung Syncmaster 2233sw: http://www.samsung.com/au/consumer/pc-peripherals/monitor/archive/LS22CMZKFV/XY/index.idx?pagetype=prd_detail&tab=specification) is actually the problem in this matter. Has anyone ever experienced or heard of the problem of having Vysnc disabled and thus causing what appears to be stuttering / FPS lag across all games because the monitor is unable to display properly? If so, a monitor upgrade would fix this matter, such as a 120hz monitor as opposed to a 60hz?
In my experience and from what I've read, disabling Vysnc in most matters actually makes smoother gameplay because of the higher FPS, but in my situation I experience very little smoothness as opposed to having Vysnc on. Please note, it's not screen tearing, it just appears much more choppy to the extent of stuttering and frame skipping.
Cheers everyone! To note; I do have the latest drivers, disabled HT and all that good stuff
THANKS!!!
Problem...
12 gb ram
Corsair 1050HX
THANKS!!!
