Sign-in / Sign-up
Any body having any trouble with the 3570k?
  • CPUs
Last response: in CPUs
May 5, 2012 4:18:32 AM
Should I stick with the 3570k or go to Microcenter and get a 2500k? :fou:
More about : body trouble 3570k
May 5, 2012 4:32:57 AM
I don't see any reason to change unless you're in need of something. Why are you considering changing? If you're staying below about 4.8 GHz, your temps will be fine and you get a little extra IPC to make up for a lower overclock.
a c 186 à CPUs
May 5, 2012 4:36:53 AM
If you mean by "stick" you already have the processor? If all means keep it! However, if you have a microcenter nearby you can buy either the 3570k or 2500k and get $50 off of any motherboard.
May 5, 2012 3:34:49 PM
Ya, I just got the box from NewEgg. I read they are HOT... this is my first build and I'm trying not to pick bad parts. I thought I would ask around from real people how they were doing. Thanks for the info. :)
While I'm at it... I've got a Corsair TX750, 550D case and H80 cooler, ASRock Z77 Extreme6 board in boxes in my room. Good choices? The Army has made me PARANOID :fou:  :lol:  :D  Thanks man...
a c 186 à CPUs
May 5, 2012 5:41:12 PM
Then start building! They really are considered "hot" on the stock cooler, and when overclocked above 4.5ghz! The H80 should keep the temperatures down easily! :)
a b à CPUs
May 5, 2012 5:43:56 PM
They H80 should keep it pretty cool. They run hot above 4.5Ghz compared to Sandy Bridge. It also is on average 10% faster than Sandy Bridge, so a 4.5Ghz Ivy bridge is pretty much on par with a 5Ghz Sandy bridge. :)
May 5, 2012 6:01:45 PM
If you compare a 3770k and a 2600/2700k on average its around 4%.
http://www.tomshardware.com/reviews/ivy-bridge-benchmar...
