V valjasme Distinguished Nov 24, 2011 1 0 18,510 Nov 24, 2011 #1 the monitor dont have any output. it's just a blackscreen and my power supply is 350 watts.. while the s[ecs of the videocard says 400watts..
bobusboy Distinguished Jul 3, 2009 764 0 19,060 Nov 24, 2011 #2 The power supply likely isn't the issue; check the cables, and check your monitors settings. If the monitor has more than one type of video input then you may have to push a button to manually switch between VGA/DVI/HDMI etc. Upvote 0 Downvote
